MHB Solving Trig Equations: Help Needed!
  • Thread starter Thread starter Drain Brain
    Trig
The discussion revolves around solving a system of trigonometric equations related to the equilibrium of a particle. The user initially struggles with the equations but successfully derives a quadratic equation for W and finds two potential solutions for W and corresponding angles θ. Both sets of solutions are validated against the original equations, confirming their correctness. However, the choice of which solution to use depends on the specific requirements of the problem, as both solutions are mathematically valid. Ultimately, the user concludes that the preferred solution is W = 240 lb and θ = 40.9°.
Drain Brain
Can you help me how to solve this system of trig eqns
$W\cos(30^{\circ})-275\cos(\theta)=0$
$W\sin(30^{\circ})+275\sin(\theta)=300$
I have tried to divide the first eqn by 2nd and I get
$\tan(30^{\circ})=\frac{275}{300\cos(\theta)}-\tan(\theta)$ I'm stuck here! Kindly help me please!
Mathematics news on Phys.org
Hey Drain Brain!
Suppose we isolate $\cos(\theta)$ and $\sin(\theta)$ in each equation, squared them, and add them.
Then we would be rid of $\theta$ and can solve for $W$.
Afterwards, we can substitute $W$ back in the first equation and solve for $\theta$.
Finally, we should check if the solutions found are actually solutions, since we may have introduced new solutions.
HI I LIKE YOU!:o
I just did what said and came up with a quadratic equation
$W^2-600W\sin(30)+300^2-275^2=0$
the two solutions are
$W=240.1$ and $W=59.86$
$\theta = 40.9$ and $\theta = 79.13$
which of them should I choose?
Drain Brain said:
HI I LIKE YOU!:o
Good! ;)
Actually, you should have 2 solutions for $\theta$ for each value of $W$...
What happens if we substitute them in the second equation?
I like Serena said:
Good! ;)
$240\sin(30^{\circ})+275\sin(40.9)=300$-->>$300=300$ $59.86\sin(30^{\circ})+275\sin(79.13)=300$---->>$300=300$
Does this mean that the values of W and $\theta$ that I get are valid solutions?
Actually the system of equations that I posted above came from a problem about equilibrium of a particle.
I was asked to find force W and angle $\theta$ to satisfy equilibrium conditions. The answer to this problem was 240 lb for W, and $\theta=40.9$. If both sets of solution are valid, why the other solution was not chosen?
Yes, they are both solutions.
It depends on the actual problem statement what to do with them.
Perhaps just a single solution was requested, perhaps there is another reason to discard one of them, or perhaps the given answer is simply incomplete.
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
