Green's Function for Two-Point Boundary Value Problem
  • Thread starter Thread starter Brian T
Brian T
Determine the Green's function for the following problem
$$-u'' + cu = f$$ in the domain D = (0,1) with BC's u(0)=u(1)=0
The Green's function is given by
$$G(x,y) =\begin{cases}
\frac{1}{W} u_0(x)u_1(y), &\text{for } 0 \leq y \leq x \leq 1, \\
\frac{1}{W} u_0(x)u_1(y), &\text{for } 0 \leq x \leq y \leq 1.
\end{cases} $$
Where W is the Wronskian of the solutions to the homogeneous equation u_0, u_1, where u_0, u_1 satisfy the boundary conditions u_0(0)=1, u_0(1)=0, u_1(0)=0, u_1(1)=1
I am able to find the Green's function assuming c = const.
To find the fundamental solutions, we solve the homogenous equation -u'' + cu = 0.
The fundamental solutions are e^{\sqrt{c}x}, e^{-\sqrt{c}x}. To satisfy the boundary conditions, choose the appropriate linear combination of these fundamental solutions. After a little algebra, I get:
$$u_0(x) = \frac{1}{1 - e^{2\sqrt{c}}}e^{\sqrt{c}x} + \frac{-e^{2\sqrt{c}}}{1-e^{2\sqrt{c}}))}e^{-\sqrt{c}x}$$
$$u_1(x) = \frac{1}{e^{\sqrt{c}} - e^{-\sqrt{c}}}e^{\sqrt{c}x} + \frac{1}{e^{-\sqrt{c}} - e^{\sqrt{c}}}e^{-\sqrt{c}x}$$
I know this is all correct (plugged in and verified my solutions).
The question I have is for c not a constant, i.e. c = c(x). Since the problem does not specify whether c is constant or a function, I would assume that it could be a function... The DE becomes
$$ -u'' + c(x)u = f $$
This would require getting the fundamental solutions by solving
$$ -u'' + c(x)u = 0 $$
which I am unsure of how to do for an arbitrary function c(x). There are certain methods for certain types of functions of c(x), but does anyone have a clue on how to solve this ODE for a general c(x)? If not do you think the problem could be referring to a constant c (in the actual chapter the author usually takes the coefficient to be an arbitrary function)? By the way, the book is numerical PDE's by Larrson
There is no general way of solving that for any function c(x). By the way, finding Green's function for the case c constant can by simplified by using cosh(cx) and sinh(cx) rather than e^{cx} and e^{-cx} .
Likes Brian T
Ohh alright, thanks. I'll try that instead :).
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
