Some Circular Motions Questions (No math)
  • Thread starter Thread starter Epsillon
    Circular
If the Earth spun fast enough for centripetal acceleration to equal gravitational acceleration, individuals would experience weightlessness due to the sensation of free fall. Water in a bucket remains inside during circular motion because both the bucket and the water fall at the same rate, creating a stable environment. A satellite's fate depends on the balance between gravitational force (Fg) and centripetal force (Fc); if Fg exceeds Fc, it will crash to Earth, while if Fc exceeds Fg, it may escape orbit. The discussion emphasizes understanding the concepts of acceleration and forces rather than relying solely on mathematical calculations. The relationship between Fc and Fg is crucial for determining orbital stability and motion.
Epsillon
1) If the Earth could be made to spin so fast that ac=g, how would this affect the apparent force of gravity on you?
2)Why doesent water in a bucket spill out when it is in circular motion?
3) What happens to a sattelite when Fg is bigger than Fc and Fg is smaller than Fc
1) We would be weightless. But I am not sure about the reason WHY. is it because the Earth is falling faster than we are ?
2) The bucket is falling at the same rate as water and therefore it catches it?
3) Fc=fg it orbits and if its fg is bigger will it go out of orbit and smaller crash into earth? Why is this? This one I have no idea.
Hi Epsillon! :smile:
(i take it c means centripetal and g means gravity)
2) If "no math" in the title is part of the instructions, then your answer is fine …
except you might want to throw in the word "acceleration" a few times, just to prove you understand what it is! :wink:
1) Consider the acceleration (and it may help you to think of the Earth as a hollow sphere, and we're standing on the inside of it :wink:)
3) Hint: will it only stay in orbit if Fc exactly equals Fg? :smile:
Thanks For the Respons!
No the questions never said that no math is required but our teacher is somewhat picky and hates students that just do all math and don't understand concepts.
So I still do not get 1. Like what if we are on the pole?
I assume if you are on the pole it makes no difference but being exactly on the equator I kinda disagree with my previous statement now because I think that we actually arent falling at all? (Is this true?)
I still can't explain 1 properly but just imagining it i think we will be weightless.
Can you prove it using math?
For 2 I think I get it completely now and thanks for pointing out that I didint use acceleration at all :)
3 I thought about it some more and now I am more confused.
If Fg is bigger wouldn't it just crash into the earth??
And smaller wouldn't it just be attracted to another planet or something and go off??
Oh and about you hint/question. Obviously it is impossible to make Fg exactly Fg so how does it work?
Oh so Fc exactly doesent equal Fg does it go in a eliptical shape?
Yes! :biggrin:
If Fc is too small, the ellipse will intersect the Earth's surface …
a crash is just an ellipse that's too thin! :wink:
And if Fc is too large, it may … ? :smile:
Fc must mean the local acceleration, so it obviously doesn't apply at the pole.
If the surface of the Earth wasn't there (at our particular place), we would be falling.
But that's not really a maths explanation …
for that, use good ol' Newton's second law … F = ma. :smile:
