Some explanation about transister
  • Thread starter Thread starter firoz.raj
    Explanation
To identify the type of transistor (PNP or NPN) from a circuit board, check the numbers on the transistor, as they can often be looked up online for more information. Transistors can be tested using the diode function of a digital multimeter; if the "diodes" are joined at the anodes, it indicates an NPN type, while joining at the cathodes indicates a PNP type. This testing can be performed even when the transistor is still on the board, although other components may complicate results. For more accurate testing, removing the transistor allows for an "hfe" gain test with most digital multimeters to determine pin connections and functionality. Understanding these methods is essential for effective transistor identification and troubleshooting.
firoz.raj
Can anyone tell me ?how should i idetify transister type ?i simple want to know .from the board.it is pnp transister or npn transister physically.Kindly let me know the idea.Any help woud be highly appreciated.
Transistors have numbers on them. Something like C115 may mean 2SC115, so you could look that up on Google.
Transistors test like two diodes joined together at one end. You test with the "diode" function of a digital multimeter, not the "ohms" function which is usually too low a voltage to turn on diodes.
If the "diodes" appear to be joined at the anodes, then it is a NPN transistor. If they are joined at the cathodes, it is a PNP transistor. The pin where they appear to join is the base of the transistor.
You can sometimes do this when the transistor is still on the board and it is also an excellent test for faulty transistors. Shorted or open diodes may mean a faulty transistor, but other components on the board may give a false impression of this.
If you can remove the transistors from the board, most digital multimeters would have a "hfe" type gain test. You can safely put the device into this in different ways until it gives good gain. Then you will know the pin connections and if the transistor is faulty or not.
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
suppose you have two capacitors with a 0.1 Farad value and 12 VDC rating. label these as A and B. label the terminals of each as 1 and 2. you also have a voltmeter with a 40 volt linear range for DC. you also have a 9 volt DC power supply fed by mains. you charge each capacitor to 9 volts with terminal 1 being - (negative) and terminal 2 being + (positive). you connect the voltmeter to terminal A2 and to terminal B1. does it read any voltage? can - of one capacitor discharge + of the...
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
