Some questions regarding Acoustic wave reflection
  • Context: Undergrad
  • Thread starter Thread starter itamar123
    Reflection
The discussion revolves around the reflection and transmission of acoustic waves in a flexible steel cable connected to a pillar, particularly in the context of electric guitars. Participants explore the factors influencing wave reflection, including material properties, geometry of the pillar, and the effects of external constraints.
  • One participant notes that the reflection coefficient is influenced by the acoustic impedance of the pillar compared to the cable, suggesting that a higher impedance leads to greater reflection.
  • Another participant proposes that a rigid and heavy pillar, such as one made of tungsten carbide, would enhance reflection, and suggests optimizing the pillar's shape for specific modes of vibration.
  • Concerns are raised about the attachment of the cable to the pillar, emphasizing the need for clean reflection of transverse waves without damaging the cable.
  • Discussion includes the idea that the geometry of the pillar, such as being shaped like a pyramid or cone, may optimize reflection based on the normal modes of vibration.
  • Some participants discuss the implications of the pillar's resonance frequencies on energy reflection, questioning how different materials and geometries might affect the interaction with the cable's waves.
  • There is a mention of the potential for the pillar to absorb energy, which could affect the efficiency of the cable as an oscillator.
  • One participant highlights the importance of the saddle or nut design in stringed instruments, indicating that this could influence the overall dynamics of wave reflection.
Participants express multiple competing views regarding the optimal material and geometry of the pillar, as well as the relevance of specific attachment methods for the cable. The discussion remains unresolved, with no consensus on the best approach or configuration.
Participants acknowledge the complexity of the interaction between the cable and pillar, including factors such as external constraints, resonance frequencies, and the specific design of the guitar's saddle or nut. There are indications of missing assumptions and unresolved mathematical considerations related to wave behavior.
This discussion may be of interest to those studying acoustics, materials science, and the design of musical instruments, particularly in understanding wave dynamics and reflection in stringed instruments.
itamar123
TL;DR
What are the general governing equations for Wave Reflection at boundary in solid-solid case?
I'm new to this subject so bear with me and I have a salad in my head. I have some fundamental question regarding wave reflection/transmission. Lets say I have a flexible steel cable connected to an end support (pillar) and waves are induced in that cable. My goal is to get the maximum amount of reflection from this setup. Picture for this case:
https://www.imagebam.com/view/MEWPXEX
<a href="https://www.imagebam.com/view/MEWPXEX" target="_blank"><img src="https://thumbs4.imagebam.com/f0/5b/80/MEWPXEX_t.png" alt="guitar.png"/></a>
I tried reading bits and pieces on this case and this is my current understanding:
The cable's waves are transverse, and so they induce shear waves (and not longitudinal) waves in the Pillar (end support).
the reflected wave amplitude is given by the reflection coefficient, and the higher the acoustic impedance of the pillar (Z2=sqrt(Rho2*G2)) compared to the cable (Z1=Rho1*C1), the higher the coefficient of reflection.
I have a couple of questions,
How does the geometry of the end support play a role? From what I read, it is recommended that the length of the pillar be at least a quarter of the biggest reflected wavelength, so assuming amplitude of 8mm of the cable, the height if the pillar h should be 2mm up and down from the connection point.
Also, How does external constraints on the pillar affect the reflection? meaning, lets say I induce some force on the sides or top of the pillar to constraint its vibration, intution tells me it stiffens it and so increases the reflection, how can I calculate this?
One last question, how does the normal modes of the pillar affect this interaction? Intution tells me that the pillar acts like a HPF or LPF, and the frequencies of the cable that match the normal modes of the pillar are not reflected back as much as the ones that dont.
In that case, will a different, maybe weird geomery reflect waves better?
Whats the connection between the normal modes of the pillar and the coefficient of reflection?
Dont refrain from Math and equations,
If someone can point me to a book/article/paper that covers this topic thoroughly, ideally, a way to make an FEA analysis on this (Using Solidworks Simulation, preferably, ansys is good as well) I'd very much appreciate it.
You need a rigid and heavy pillar, that is set in a solid foundation. Consider tungsten carbide as a pillar material.
The pillar should be shaped like a pyramid or a cone. The pillar shape may be optimised for some modes of vibration.
Thanks for the reply,
Im looking for a more in depth answer in case one of the parameter changes.
What type of instrument are you contemplating?
How do you intend to attach the cable to the pillar, so transverse waves are reflected cleanly, without fatiguing and breaking the wire?
Maximum energy reflection suggests you would also benefit from minimum loss in the cable. So why do you propose using a cable when you could use a solid wire with less internal friction.
Actually I'm contemplating regular Electric guitars, there's a lot of misunderstading surronding that topic and lots of myths so I wanted to investiage.
Your suggestion of tungsten/tungsten carbide seems to be accurate, I just want deeper understanding.
The string carries a transverse wave which involves an interchange of energy between displacement and KE. Notice however that tension increases at every peak of the displacement wave, so has a component at twice the frequency, so the pillar is excited at twice the frequency of the generator. In principle this produces a transverse wave on the pillar, although we would usually make the pillar short and fat to make this negligible. It is possible that the pillar would have a resonance at this double frequency, but I think we would usually expect the pillar to simply absorb some energy. Unlike an electrical wave, I don't think we can just assume the approximation that the wave on the string turns through 90 degrees and travels down the pillar.
The long neck of an electric guitar generates more flexibility than the pillars. The neck is designed to counter and balance the string tension. There is little advantage in making the pillars more rigid, without first fitting a deeper and more rigid neck.
I know, but now I just want to understand the saddles part of it.
Awesome insights! didnt think of it. how short and fat is enough though? finding the resonance frequencies of the pillar is pretty easy and I understand the physics of it, but not the other parameters.
Lets say theortically the first fundamental of the pillar is far higher than the 20th fundamental of the cable and im neglecting higher frequencies, what happens to the energy those fundamentals carry? they dont all fully reflected back, dont they?
How does the geometry (and therefore the fundamental frequencies) of the pillar play a role?
Would a Tungsten pillar that has some matching frequencies be better than a stainless steel or cermaic pillar that has much less matching frequencies?
If the pillar has a self resonance far above the twice frequency of the string, then each cycle it will remove a small amount energy from the string and store it in its elasticity. We can say the pillar will add shunt elasticity and friction to the string, lowering its frequency and reducing its efficiency as an oscillator. Of course, the pillar can also transmit energy to the mounting surface, which might have its own resonances and possess radiation resistance, so the loudness will increase, and the quality of the sound will alter.
Hi @itamar123. Each end of the vibrating part of a guitar string rests on a support. That means the vibrating part of the string is not attached to the side of a pillar.
An analysis of a string attached to the side of a pillar doesn't seem relevant. Or maybe I've missed something?
Hey, I didnt want to get into the specifics of it as I wanted to keep it simple to understand the basic physics first, so I described an idealized system.
If you want to get more specific, it depends on the type of saddle or nut the guitar (or any other stringed instrument for that matter).
A locking nut is more similar to the problem I described.
  • · Replies 16 ·
  • · Replies 20 ·
