Some work and elastic energy problems
The discussion revolves around solving two physics problems related to energy. The first problem involves calculating the gravitational potential energy of a skier on a ski lift, where it's clarified that the law of conservation of energy is not necessary for this specific calculation. The second problem pertains to a toy dart shooter, where the elastic potential energy of the spring needs to be determined, followed by calculating the dart's speed as it exits the toy. It's confirmed that using the kinetic energy formula E_k = 1/2mv^2 is appropriate for finding the dart's speed. The conversation highlights the importance of correctly applying energy principles to solve these types of problems.
Byrgg
I'm having trouble trying to figure out some of the questions from my homework, here are the problems:
1. A 68.5 kg skier rides a 2.56 m ski lift from the base of a mountina to the top. The lift is at an angle of 13.9 degrees to the horizontal. Determine the skier's gravitational potential energy at the top of the mountain relative to the base of the mountain.
Because of the law of conversation of energy that I'm supposed to apply, I figured that the total energy would be the same at both points. But when I tried to figure out the numbers, I got two unknowns, and I wasn't even sure if I had organized the problem properly. Any help here would be greatly appreciated.
2. A child's toy shoots a rubber dart of mass 7.8g, using a compressed spring with a force constant of 3.5 x 10^2 N/m. The spring is initially compressed 4.5cm. All the elastic potential energy is converted into kinetic energy of the dart.
a) What is the elastic potential energy of the spring?
I got this part.
b) What is the speed of the dart as it leaves the toy?
I was thinking of using E_k = 1/2mv^2 to calculate this, is this right?
There's more questions, but I'll get to them after these have been solved.
I got this part.
Regarding part 1, you don't need to apply the law of energy conservation, since you're only asked to determine the gravitational potential energy of the skier at the top of the mountain.
Regarding part 2, apply the law of energy conservation.
Part 2 of which question?
Sorry, I wasn't specific enough - question 2, part b.
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
