Sound Power Level (SPL) of a loudspeaker
  • Thread starter Thread starter Rorshach
    Power Sound
The discussion revolves around calculating the Sound Power Level (SPL) of a loudspeaker at different distances and power inputs. The initial SPL is given as 115 dB at 1 meter with 1 watt input, and calculations show that at 6.1 meters, the SPL should be adjusted using the inverse square law, resulting in a value of 99.3 dB. However, a typographical error in the textbook is identified, where the correct formula should involve a positive sign, leading to a revised SPL of 108.4 dB when the power input is decreased to 0.22 watts. The participants clarify the use of logarithmic formulas for calculating changes in SPL, emphasizing the importance of correctly applying signs based on power comparisons. The final consensus highlights that the change in SPL depends on the ratio of final to initial power levels, affecting the overall sound pressure level calculation.
Rorshach
This is a simple problem from a textbook I am reading, and everything below is written word by word and sign by sign from said textbook. Formulas given in the book just don't give the result authors claim they do:
An input of 1 W produces a SPL of 115 dB at 1 m. What is the SPL at 6.1 m?
SPL = 115 - 10log(0.22/1) = 115 - 15.7 = 99.3 dBThe assumption made in the 20log(6.1) factor is that the loudspeaker is operating in a free field and that inverse square law is valid in this case. This is a reasonable assumption for a 20-ft distance if the loudspeaker is remote from reflecting surfaces. A loudspeaker is rated at a sound- pressure level of 115 dB on axis at 1 m with 1 W into 8Ω. If the input were decreased from 1 to 0.22 W, what would be the sound pressure level at 1 m distance?
= 115 - 6.6
= 108.4 dB
Note that 10log is used because two powers are being compared.
Rorshach said:
SPL = 115 - 10log(0.22/1) = 115 - 15.7 = 99.3 dBThe assumption made in the 20log(6.1) factor...
Looks like the book has a typographical error. It appears that the quantity given in green was meant to be 20log(6.1).
I am sorry, in that case it was my typo. In the book it stands 20log(6.1). It's the second equation that doesn't work out. I made sure it is exactly like in the textbook, so no typo there.
Are you saying that the following numbers don't work out?
= 115 - 6.6
= 108.4 dB
It looks OK to me. Never mind, there is a sign error. The equation SPL = 115 - 10log(0.22/1) should not have a minus sign on the right. It should be positive. That is, it should be
SPL = 115 + 10log(0.22/1) = 115 - 6.6 = 108.4 dB
that is right. I have a question: When should it be minus sign and when should it be plus? What determines that?
The change in sound level is always 10Log(If/Ii) where If is the final intensity and Ii is the initial intensity.
For a point source of power P, I = P/(4πr2). So, if you keep the power constant while changing r, you have that the change in sound level is
10Log(If/Ii) = 10Log(ri2/rf2) = 20Log(ri/rf) = -20Log(rf/ri)
but here we are dealing with pressure, and it would have to be SPL = 115 + 10log(0.22/1) for the correct result- how do I correlate power and pressure correctly?
If p is the "sound pressure" (i.e., the amplitude of the pressure variation in a sound wave), then it turns out that the intensity of the sound, I, is proportional to p2. So, the sound pressure level can be written as
SPL = 10 Log[I/I0] = 10 Log[p2/p02] = 20 Log[p/p0]
The "0" subscript refers to some standard reference level (usually corresponding to the threshold of hearing). If you are only interested in changes in SPL, then
ΔSPL =10 Log[If/Ii] = 20 Log[pf/pi].
In your particular problem, you did not have to work with any sound pressure values, p.
I still don't understand how I'm supposed to get
In the first equation it was very intuitive, and produced expected result. But second equation just makes no sense:
in the logarithm (just like authors state in the book is 10log, because two powers are being compared) we have a fraction with wattage in nominator (after change, 0.22W) and denominator (before change, 1W, refference value). And for this equation to produce expected result we have to have either - 10log(1/0.22), which makes no sense since refference value is in nominator, or +log10(0.22/1), which I have no idea where it came from.
I'm not sure where you are having difficulty.
In terms of power changes, the change in SPL is
ΔSPL = 10 Log[(final power)/(initial power)]
So, in your specific problem, ΔSPL = 10 Log[(.22 W)/(1 W)] = 10 Log[.22/1] = -6.6 decibels
Logarithms obey the property Log[a/b] = - Log[b/a]
So, Log[(final power)/(initial power)] = - Log[(initial power)/(final power)]
So, you can just as well write the change in SPL as
ΔSPL = - 10 Log[(initial power)/(final power)] = - 10 Log [1/(.22)] = -6.6 decibles.
I mean the general formula for this would be:
SPL = G - ΔSPL
where G is a given value of SPL at a given distance.
and all the signs in the formula are the same, only values of SPL, G and ΔSPL change and can be negative or positive, right?
Usually, the symbol Δ indicates a change given by the final value minus the initial value. Thus,
ΔSPL = SPLf - SPLi.
Rearranging this gives
SPLf = SPLi + ΔSPL.
Note the plus sign on the right hand side.
ΔSPL is related to the change in intensity, I, of the sound according to ΔSPL = 10Log[If/Ii].
If If > Ii then ΔSPL is positive. If If < Ii then ΔSPL is negative.
So, SPLf = SPLi + 10Log[If/Ii].
