Sound wave questinos my tutor couldnt even figure out
The discussion revolves around solving sound wave problems involving the Doppler effect and sonic booms. The first problem involves calculating the frequency of sound waves reflected from a moving truck, highlighting the need to account for double Doppler shifts. The second problem focuses on determining the altitude of a plane based on the time it takes for its sonic boom to reach an observer, emphasizing the importance of understanding the travel time of sound. The third problem examines the speed of a moving flatcar based on beat frequency, with clarification that the direction of movement affects the Doppler shift. Participants ultimately resolve the issues with collaborative insights, particularly on the nuances of the Doppler effect.
HobieDude16
sound wave questions my tutor couldn't even figure out
allright, well, i tried these problems, really thought i knew what i was doing, cause this section has been fairly easy, but i just can't get a couple of them! maybe you guys can help?
1 A stationary motion detector sends sound waves of 0.300 MHz toward a truck approaching at a speed of 32.0 m/s. The speed of sound in the air is 343 m/s. What is the frequency of the waves reflected back to the detector?
______ MHz
my method was to use the whole "f=fo[(v(+-)vo)/(v(+-)vs)] ordeal, using v=343, fo=.3, vo=0, and vs=32
so i worked it out like that, got .330868, wrong answer... my tutor's idea was that its not doplar at all, and just to enter the orig f, .3, but that wasnt right either... i have no idea what i did wrong
2. A plane flies at 1.15 times the speed of sound. Its sonic boom reaches a man on the ground 1.00 min after the plane passes directly overhead. What is the altitude of the plane? Assume the speed of sound to be 330 m/s.
______ m
this one should be easy as well, i did sin(theta)=(1/machnumber) and solving for the angle, then using that, as well as the time (60s) times the speed of sound (330 in this case) to find the hypotenuse of a triangle... did that, solved for the missing side, got 17217.39m, but that's wrong... any ideas?
and lastly
3. A trumpet player on a moving railroad flatcar and a second trumpet player standing alongside the track both play a 440 Hz note. The sound waves heard by a stationary observer between the two players have a beat frequency of 5.0 beats/s. The speed of sound in the air is 343 m/s. What is the flatcar's speed?
_____ m/s
for this one, figured id use the whole "fb=f1-f2" to get the freq, so that owuld be 445 Hz. then plug the numbers into the f=fo[(1/(1-(vc/vs))] with f=445Hz, fo=440Hz, vs=343m/s, and solve for vc... got 3.8539, wrong...
those were all the problems out of about 15 that i couldn't get, and i thought i just didnt grasp the concept, but when my tutor couldn't do them, i figured id ask some other experts for their opinions... any help would be greatly appreciated
There is a double shift because of the reflection. The original sound is doppler shifted up when received by the approaching truck. When it is reflected back to the detector, it is doppler shifted upward again.
The sound travels along the hypotenuse, so the time of travel is \Delta t = L_{hyp}/v_{sound}. But that time is not 60 seconds. It is 60 seconds + the time it takes for the plane to fly from the opposite end of the hypotenuse to the point directly overhead (60 + L_{horiz}/v_{plane})
fb=f1-f2. So the approaching sound wave is doppler shifted to 445 Hz. Use:
f = f_0 \frac{v_{sound}}{v_{sound} -v_{source}}
I get a speed of about 4m/sec.
AM
well, i got the first 2, a friend helped me out, but the 3rd is still a mystery, you said you got about 4m/sec, which is basically what i got with the 3.85m/s, and i don't think theyd mark it wrong with an exact answer... so that one is still up for grabs on help. thanks for the help though man!
It doesn't say which direction the car is going so there are two potential answers which are slightly different (the doppler shifted frequency would be 435 Hz) and differ by a - sign. So maybe they are looking for both answers.
AM
ha, that's it, they wanted the negative answer, just make it postive... its negative cause the train is going away! hahaha, thanks man for the help!
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
