Why Do Objects Float in Space Station (SS)?
In summary: If it did that on a continuous basis then objects would "appear to move to the back of the SS opposite the direction of horizontal acceleration".
paulfr
193
I am confused about why astronauts and objects around them float in The Space Station [SS].
In space a long way from massive bodies, objects float.
In free fall, objects behave as if in a Gravity free region; they also float.
But the SS has 90% of the Gravity that exists on Earth.
PLUS
The SS is not accelerating in orbit, so its velocity is constant.
So shouldn't objects sink toward the Earth
AND
move toward the rear of the SS, opposite the direction of motion
[just as a rock in a wagon appears to move to the back of the wagon].
Which assumption or reasoning is flawed here ?
This doesn't have anything to due with GR at the moment, it's purely classical physics. Your arguments are purely Newtonian.
If the space station was not accelerating, it would be moving in a straight line. But it's not moving in a straight line, it's moving in a circular orbit.
Thus, the space station is accelerating, because it's not moving in a straight line. The type of acceleration associated with moving in a circle is known as "centriptal acceleration". The centriptal acceleration of the space station is equal to the Earth's gravity at its height.
Yes the Centripetal Acceleration is created by Gravity.
So the SS is in free fall vertically.
That would explain the floating objects vertically.
But the SS must also fire engines perpendicular to the fall to stay
in orbit. If it does this on a continuous basis, then objects would
horizontal acceleration.
If they fire only intermittently to maintain orbit height then
the motion when not accelerating is inertial and again objects float.
BTW, this Q came about because Einstein's thought process
about GR began with his Equivalence Principle of Gravity and Acceleration.
Free fall is part of the reasoning that led him to GR and geodesics.
in orbit.
While they fire the engines, the station is not in free fall anymore, so the free falling astronauts accelerate relative to the station.
I don't see what our question has to do with Newtonian gravity vs. GR. Both models explain the relative acceleration between station and astronauts.
The ISS is in free fall. It doesn't "fire engines perpendicular to the fall to stay
in orbit". It only does that occasionally to prevent orbit decay due to air drag and solar wind.
FAQ: Why Do Objects Float in Space Station (SS)?
1. What causes objects to float in the Space Station?
The main reason why objects float in the Space Station is due to microgravity. In orbit, the gravitational pull of the Earth is counteracted by the centrifugal force of the Space Station's orbit, resulting in a state of freefall. This creates a near-weightless environment, causing objects to float.
2. Can objects float in the Space Station even with no air?
Yes, objects can still float in the Space Station even with no air because it is not the presence of air that causes objects to float, but rather the absence of gravity. In a vacuum, objects will still float if they are in a state of freefall.
3. Do objects float differently in the Space Station compared to on Earth?
Yes, objects do float differently in the Space Station compared to on Earth. On Earth, objects fall to the ground due to the force of gravity. In the Space Station, objects are in a constant state of freefall, causing them to float instead of falling to the ground.
4. Can astronauts control the floating objects in the Space Station?
Yes, astronauts can control the floating objects in the Space Station with their hands or by using special tools. While the objects may appear to be weightless and effortless to move, astronauts must still use force and precision to manipulate them in the microgravity environment.
5. Why do astronauts float in the Space Station?
Astronauts float in the Space Station for the same reason why objects float - due to microgravity. Without the force of gravity pulling them down, astronauts are able to move freely and perform tasks in a near-weightless environment. This allows them to conduct experiments and complete tasks that would be difficult or impossible to do on Earth.
