Launch Velocity of Spacecraft at ISS: Solving for v_L
  • Thread starter Thread starter compwiz3000
    Iss Spacecraft
To determine the launch velocity for a satellite in a circular orbit at 357.1 km, the energies can be equated using the formula that incorporates gravitational parameters. The mechanical energy conservation principle is applied, leading to the conclusion that the launch velocity must be sufficient to achieve a stable orbit. The discussion highlights that a direct launch to the ISS is not feasible due to the need for sufficient angular momentum and velocity to maintain orbit above the atmosphere. The trajectory typically involves an initial boost to reach a higher altitude before achieving the necessary orbital velocity. Overall, the approach emphasizes the importance of energy conservation and orbital mechanics in satellite launches.
compwiz3000
If we launch a satellite to a circular orbit around the Earth at height 357.1 km, to find the velocity needed at launch, do we just set the energies equal?:
<br /> - \frac {\mu}{2\left(r_E + h\right)} = \frac {v_L^2}{2} - \frac {\mu}{r_E}<br />
and then solve for v_L?
\mu = GM, where M is the mass of the Earth.
Then, in space, the mechanical energy is
<br /> \frac {v^2}{2} - \frac {\mu}{r}.<br />
Using centripetal force, we have
<br /> \frac {m v^2}{r} = \frac {\mu m}{r^2} \implies v^2 = \frac {\mu}{r},<br />
so the mechanical energy is
<br /> - \frac {\mu}{2r}.<br />
Since the mechanical energy is conserved at the surface, we set it equal to that mechanical energy to find the launch velocity.
and then solve for v_L.
Is my reasoning for the launch velocity correct?
If you gave the satellite the needed velocity at launch, the satellite would orbit the Earth with a perigee that would be several miles above the treetops. Secondly, because the Earth is rotating with an angular speed of over 1000 mph at the equator, the easterly velocity at Cape Canaveral is about 1000 cos(28 degrees) = 880 mph.
What do you mean by "needed velocity at launch"?
And is my approach correct?
You have correctly identified the vertical velocity required to reach the ISS orbit, and the ISS orbital velocity, but the actual trajectory is probably one that first reaches the top of the atmosphere (50 Km?) and an orbital velocity (~7880 kps (kilometers per sec))that would be needed to reach the minimum orbital momentum and maintain a circular orbit in case of loss of thrust. Then, by boosting the velocity to about 7960 kps, the satellite would be on an elliptical orbit that would reach the ISS orbit as an apogee. But when arriving at the ISS orbit, its velocity would be only 7610 kps, so it would have to boost its velocity to about 7700 kps to maintain a circular orbit. At this time, its period would be about 91.6 minutes. By dropping down 10 km in altitude, it could shave maybe 12 sec per revolution and catch the ISS in a few turns if necessary.
The path you are describing is the Hohmann transfer orbit, right?
How much velocity boost would I be saving in your case?
It is not feasible to directly launch to the ISS?
Also, if I use the energy conservation law with an initial thrusting of v_i and a final velocity of 0, the satellite would not have enough velocity to undergo circular motion, correct?
compwiz3000 said:
The path you are describing is the Hohmann transfer orbit, right??
Yes.
How much velocity boost would I be saving in your case??
Don't know.
It is not feasible to directly launch to the ISS??
For safety reasons, the satellite has to quickly reach an orbital (not vertical) velocity that will have sufficient angular momentum to circle the Earth above the atmosphere.
Probably not. Any orbit that begins on the Earth with final velocities will be on an elliptical orbit (neglecting air drag) that intersects the Earth in less than one revolution.
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Thread 'A scenario of non-uniform circular motion'
(All the needed diagrams are posted below) My friend came up with the following scenario. Imagine a fixed point and a perfectly rigid rod of a certain length extending radially outwards from this fixed point(it is attached to the fixed point). To the free end of the fixed rod, an object is present and it is capable of changing it's speed(by thruster say or any convenient method. And ignore any resistance). It starts with a certain speed but say it's speed continuously increases as it goes...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
