matheinste said:
JesseM have a nice holiday. Rest your brain.
Thanks! But I do have time to comment on your most recent post:
matheinste said:
I am more at home now with what is going on with Lorentz transforms but bear with me although i am taking it slowly,step by step . Just focusing on length contraction for now. Is it possible in principle for an observer in B to use his own measuring rods to measure directly or indirectly lengths in A.
If a rod in B of rest length in X as measured by an observer in B is made to pass a rod of rest length X measured in A by an observer in A, next to it in space i believe we can compare them and see a difference in length.
Yes, in fact the coordinate systems of SR are based on the idea that a given observer assigns coordinates to events using only
local readings on a system of rulers and clocks at rest with respect to themselves, with the clocks synchronized in their own rest frame (because of the relativity of simultaneity, different observers disagree on what it means for clocks to be synchronized--each synchronizes their clocks using the assumption that light signals move between the clocks at a speed of c in their own frame--so a given observer will find that the clocks of another observer are out-of-sync as measured in the first observer's rest frame). For example, if I see a distant event occurring right next to the x=50 light-seconds mark on my ruler, and the clock in my system that is sitting right next to that mark reads t=20 seconds at the moment the event occurs in its local neighborhood, then I assign that event coordinates x=50 l.s., t=20 s in my coordinate system. The "length" of a moving object is defined by looking at two events at either end of the object which have the same time-coordinate in my system, so if the back of an object is passed next to the x=35 l.s. mark on my ruler when the clock at that mark reads t=19 s, and the front of the object passes next to the x=38 l.s. mark on my ruler when the clock at
that mark reads t=19 s, then I can say that the moving object is 3 l.s. long in my frame.
matheinste said:
Also am i correct in believing that each observer (frame A and frame B) will see the other's rod contracted, there must be symmetry as neither frame is preferred or regarded as at absolute rest. I cannot remember seeing the mutual contraction ever stated explicitly although the comparable result for clock rates is often presented as a "paradox", which of course it is not.
Yes, it's symmetrical, if we have two observers in motion relative to one another, each observer's ruler/clock system will measure the marks on the ruler of the other observer to be shrunk relative to their own. This may be a bit hard to visualize, so you might want to take a look at the diagrams I posted in
this thread a while back, showing how each ruler/clock system can see the other one's marks shrunk and the other one's clocks slowed down, yet they always agree on which markings/times on one ruler coincide with which markings/times on the other...it has to do with the relativity of simultaneity again, and the fact that each system measures the other one's clocks to be out-of-sync as well as slowed down.
