Spark gap switch and 2N6798 in PSPICE
15 replies · 9K views · last reply
yi ru huang
Error is like " no PSPICE template for 2N6798 , spark gap switch
how to find the .ilb of spark gap switch and 2N6798?
thank for your help.
The JEDEC part number 2N6798 is made by International Rectifier as the IRFF230.
There is a spice model for the IRFF230 in this collection, you may need to modify it for pspice.
http://espice.ugr.es/espice/src/modelos_subckt/spice_complete/POWMOS2.LIB
A spice model for the similar IRFF130. Has different specs.
http://www.irf.com/product-info/models/spice/spice.zip
There has also been a long running discussion of spark gap modelling on the LTspice group.
Using spice to model sub-sections individually can be very quick and useful, that is what spice was designed to do. The problem is that users get carried away and try to integrate the entire project into one simulation. It is not surprising that a simulation will be very slow when 10 seconds of project time is simulated with a time step of 10nsec simply because there was a digital component present in a small part of the simulation.
An accurate spark gap simulation is a problem because it has nanosecond breakdown followed by a one second recovery. The triggering of spark gap breakdown, as a load, can be done with a zener diode and SCR structure. The result of the spark gap breakdown, as a source, can be simulated by a voltage step. The problem comes when the two are coupled into the same model. The simulation needs to be split into two independent modules, one on each side of the spark gap.
Before modelling spark gaps see; https://en.wikipedia.org/wiki/Paschen's_law
Thank your reply.
I tried ,but the new error like this.
I am not sure what the mistake i made
Can you give me suggestions about this?
thank you very much.
PSpice schematic of a circuit with a 25Vdc source V4, resistor R2, MOSFET U1 IRFT230, capacitor C1 40uF, transformer TX1, spark gap switch S1, capacitor C2 0.17u, 2.5kV source V2, resistors R1 5M, R3 1k and R4 0.1, and pulse source V3 with V1 0V, V2 6V, TD 0s, TR 1s, TF 1s, PW 0s, PER 2s.
Screenshot of a SPICE netlist text file with an error message at the bottom reading: ERROR(ORPSIM-15108): Subcircuit IRFF230 used by X_U1 is undefined.
Do not do all at the start. You should use a simple circuit at the start of modelling.
Why do you specify and use IRFF230 ?
I will take me some time to make a .MODEL IRFF230 VDMOS( . . . )
Use another model until IRFF230 is available. I use IRFH5300.
The IRFF230 is in a TO-205AF (TO-39) package. It has low power.
A Mosfet is low power only when zero current with voltage, or zero voltage with current.
Your mosfet circuit is unusual. You must use pulse control of the gate. I have changed the circuit.
I have LTspice. See the attached circuit.
When M1 turns on, R1 limits the current through the transformer primary to Ip = V1 / R1 amp.
When M1 turns off, D1 conducts current through L1 to prevent voltage spike.
I do not understand your switch connections.
LTspice schematic of a MOSFET-switched transformer circuit: 25V source V1 with R1 = 1 ohm, R3 = 10m, diode D1 (RF2001T4S), M1 (IRFH5300) driven by pulse source V2, coupled inductors L1 and L2 at 10µH with K1 = 1.00, load resistor R2 = 5MEG, capacitor C1 = 0µ17 and 2.5kV source V3, with a '?' marked near the secondary.
thanks for your apply
Circuit schematic of a spark gap switch driving an exploding foil initiator: a V_TUN input through 1 Ω and 40 µF CT to a 2N6798 MOSFET, a transformer TR, a spark gap between OE and AE, a 5 MΩ resistor and 0.17 µF capacitor to 1 kV, and a CVR load with a discrete EFI image.
It is circuit from paper
I want to simulate this circuit with pspice.
This switch is spark gap switch.
But i do not know how to do
i am not a Electrical Engineering student ,so i am very confused about that
What is Discrete EFI ? Is it for high speed flash photography ?
I can model the circuit for you. But I need more information.
Please post a link or attach the paper with the circuit diagram.
The circuit cannot be modeled until design is finished.
High voltage to trigger spark gap. Comes from a pulse transformer with high turns ratio. 1 : 50 ?
Design of transformer. Requires specification of spark gap device part number and data sheet.
Have you selected a three terminal spark gap component ?
What is part number for three terminal spark gap ?
Here are some spark gap examples and data.
http://www.highenergydevices.com/products/three-electrode%20/
Start with application note download; AN-TG-10 Use of Triggered Spark Gaps.
AN-TG-20 TX Miniature Triggered Spark Gaps Description and Use.
Also; Datasheets; TX Series Datasheet. Selection Guide; Three-Electrode Triggered Spark Gaps
AE = adjacent electrode? Adjacent to trigger = main electrode.
OE = opposite electrode? Opposite to trigger.
Spice is confusing for beginners.
1M = 1m = 1e-3 = 10-3
1Meg = 1meg = 1e6 = 106
1uF = 1f = 1 femto = 1e-15 = 10-15
The MT4206 pulse transformer was used for original simulation.
It has only 1:1:1 turns ratio. It cannot be used for real circuit.
The trigger voltage must be HV, maybe 1kV. So turns ratio must be 25V : 1kV = 1 : 40.
Spice transformer ratio is set by inductance.
Inductance is proportional to n^2. So 1 : 40 turns ratio is 1.0uH : 1.6mH.
Attached is simple spice model of circuit and switch.
It shows same response as Fig 7 of Baginski Et Al. Micromachined Planar Triggered Spark Gap Switch.
  • LTspice simulation: plot of I(Refi) against time from 0 to 1.2 microseconds, a damped oscillating current peaking near 1.7 kA, with schematic of a spark gap triggered circuit below.
PSpice schematic of a pulsed circuit: 25V source V4 and R2 feeding C1 40nF, a MOSFET IRF230 driven by pulse source V3, L1/L2 coupled inductors 1nH and 1600nH, switch S1 labelled SGreak, R3 120, L3 30nH, C2 0.17nF, R4 0.0249, R5 0.18, R6 5M and a 1kV source V5.
PSpice simulation plot on a black background: red curve of current rising from 0 A at about 0.1 us to about 10 A by 0.5 us and then flattening, with a flat green trace at 0 A; axes time (0 to 1.2 us) and current (-5 A to 10 A).
Thanks for your reply very much.
I tried,but my result is wrong.
thanks for your help.
(I do not have .ilb of IRFH5300.)
DO NOT use “F” or “f” for capacitance with SPICE. It is sometimes seen as 1e-15 = 1 femto = 10-15.
Change C1 from 40nF to 40u
Change C2 from 0.17nf to 0.17u
Change L1 from 1nH to 1u
Change L2 from 1600nH to 1600u
Change R6 from 5M to 5MEG
What is your transformer coupling? Ktran L1 L2 1.000
What is your switch specification? .MODEL Sbreak SW(RON= ROFF= VT=500 )
Use any MOSFET that works in model. You may need higher voltage from V3.
The IRFF230 is old. There are now faster components for that application.
Because I follow your design steps, however, the result seems weird.
So Could you please send me your LTSPICE project file so that I can figure out the difference between yours and mine.
Thanks for your explain in detail.
Attached is file SG-4.asc.txt , remove the .txt to make SG-4.asc which is LTspice file.
Blue text is comment. Black text is Spice command or parameter values.
I do not use Pspice because it is limited or expensive.
LTspice is free. LTspice is not limited. There is a big LTspice users group.
The design of the EFI trigger pulse transformer is never openly discussed.
Patents show “pulse transformers” and “piezoelectric transformers” being applied to EFI.
Attached is the Perkin Elmer documentation for spark gaps and trigger transformers.
Chinese document; Design of High-voltage Transformer in Small-scale Pulsed Power Experimental Device.
http://en.cnki.com.cn/Article_en/CJFDTotal-CSJS201201009.htm
This Canadian article has Pspice models for the spark gap and EFI.
http://cradpdf.drdc-rddc.gc.ca/PDFS/zba33/p498223.pdf
The JAN TX 2N6798 is referenced in US documents because it is a military specified device that works in this application.
There are now better MOSFETs available without mil-spec. They are faster and have lower resistance.
Thank for information of spark gap and EFI you provide
I think I need a little time to read this information.
Thanks so much
