How Much Heat Is Needed to Convert 1 kg of Ice at -100°C to Steam at 100°C?
Ignition
How much heat is needed to convert 1 kg of ice at −100C to steam at 1000C?.
Remember ice and water do not have the same specific heat.
I can use the relation for specific heat?
You will have to use latent heats as well for phase changes.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
