Spectral distribution of light source -> Kelvin degrees?
The discussion focuses on calculating the correlated color temperature (CCT) of various fluorescent light sources based on their spectral power distribution. The initial inquiry involves mapping spectral distribution to CIE XYZ-space and then deriving the CCT value. Participants highlight the limitations of using Kelvin temperature for classifying light sources, particularly in aquaristics, where it may not accurately represent the light's appearance. Daniel Larsson shares methods, including the Robertson algorithm and a polynomial formula, to compute CCT from chromaticity values. The conversation emphasizes the need for precise calculations to better understand the color characteristics of different lighting options.
defdac
Hi all, new here (from Sweden, so excuse my english).
I would like to take the spectral power distribution of a light source (first and foremost different kind of flourescents, not black bodies) and calculate the kelvin temperature of the light emitted from the light source.
With the help of this page I can map the spectral distribution to a point in CIE XYZ-space:
http://www.fourmilab.ch/documents/specrend/
But how do I get from the point in CIE space to a CCT value (Correlated Color Temperature)?
Best Regards
Daniel Larsson
http://www.defblog.se
Science news on Phys.org
A thermal source doesn't give only a single colour in CIE space.
You can calculate the peak intensity wavelength from the temperature by Weins law
temperature (kelvin) = 3mm/(Peak wavelength)
Very true. Using Kelvin temperature to "classify" light sources is terrible inaccurate, but very common in aquaristics. The measure will not be useful for anything but give a feeling for how "cold" or "blue" a light source will feel when lighting an aquarium.
I will use the calculations to demonstrate how inaccurate Kelvin is for classifying lighting for aquariums.
Thanks! The way I'm currently on is to calculate a table with a range of Kelvin temperatures for a black body and it's XYZ-values, see below and then calculate a XYZ-value for a spectral distribution of a lamp:
Temperature x y z R G B
1000 K 0.6527442957285721 0.34446802071827504 0.002787683553152811 256 1 0 (Approximation)
1500 K 0.585718766278037 0.393121765513689 0.02115946820827409 256 32 0 (Approximation)
2000 K 0.5266807512026125 0.4132982294836405 0.060021019313747044 256 59 2
2500 K 0.4770003160416207 0.4136800591446971 0.10931962481368226 256 89 17
3000 K 0.4369398558648342 0.40408423250821457 0.15897591162695127 256 116 38
3500 K 0.40531559706388376 0.3907328491921704 0.20395155374394572 256 140 64
4000 K 0.38045474513712557 0.3767715057475733 0.24277374911530103 256 162 94
4500 K 0.3608055946466982 0.3635766668080745 0.2756177385452273 256 181 126
5000 K 0.3451217464002835 0.3516474876353892 0.30323076596432724 256 199 158
5500 K 0.3324570898678045 0.34108138423791684 0.32646152589427857 256 214 190
6000 K 0.32210778539222723 0.3318057887225378 0.3460864258852349 256 227 222
6500 K 0.3135520064160987 0.3236863676191689 0.36276162596473244 256 239 252
7000 K 0.3064010901419602 0.3165757555677976 0.37702315429024225 232 227 256
7500 K 0.30036311593555104 0.31033421627575664 0.3893026677886923 211 214 256
8000 K 0.29521660278236267 0.30483724626545455 0.3999461509521829 195 204 256
8500 K 0.29079170704681706 0.29997725681871723 0.4092310361344656 181 196 256
9000 K 0.2869567803173985 0.2956627174292652 0.4173805022533363 170 188 256
9500 K 0.28360870852781944 0.2918163519505964 0.4245749395215841 161 182 256
10000 K 0.28066591376783356 0.2883731181549254 0.43096096807724116 154 177 256
A common bulb in aquaristics is for example the Philips Aquarelle which I've calculated having the following values, it's rated 10000K from the manufacterer:
0.26023360920281896 0.2958774677980403 0.44388892299914084 94 195 256
As you can see the XY values are near the 10K blackbody XY values.
So my solution would be to generate a table of blackbody XYZ-values for all temperatures between let's say 1000 and 40000 Kelvin and then compare the XYZ-value for the lamp I want to calculate the CCT for with this table and see what temperate is the closest?
A somehate naïve approach I guess...
Hi again, I think I've found a couple of solutions.
Robertsons algorithm:
http://www.brucelindbloom.com/index.html?Eqn_XYZ_to_T.html
Also I stumbled over this PDF:
http://www.nadn.navy.mil/Users/oceano/raylee/papers/RLee_AO_CCTpaper.pdf
That PDF reduced the fairly complex algorithm to this polynomial formula (3000-50000 K):
n = (x - 0.3366)/(y - 0.1735)
CCT = -949.86315 + 6253.80338*exp(-n/0.92159) + 28.70599*exp(-n/0.20039) + 0.00004*exp(-n/0.07125)
Where X and Y is the chromaticities calculated from the spectral distribution with the program made by John Walker:
I implemented both the Robertson algorithm and used the polynomial formula and I receive almost the exact same values from both.
Best Regards
Daniel Larsson,
Thread 'A quartet of epi-illumination methods'
Well, it took almost 20 years (!!!), but I finally obtained a set of epi-phase microscope objectives (Zeiss). The principles of epi-phase contrast is nearly identical to transillumination phase contrast, but the phase ring is a 1/8 wave retarder rather than a 1/4 wave retarder (because with epi-illumination, the light passes through the ring twice). This method was popular only for a very short period of time before epi-DIC (differential interference contrast) became widely available. So...
I am currently undertaking a research internship where I am modelling the heating of silicon wafers with a 515 nm femtosecond laser. In order to increase the absorption of the laser into the oxide layer on top of the wafer it was suggested we use gold nanoparticles. I was tasked with modelling the optical properties of a 5nm gold nanoparticle, in particular the absorption cross section, using COMSOL Multiphysics. My model seems to be getting correct values for the absorption coefficient and...
After my surgery this year, gas remained in my eye for a while. The light air bubbles appeared to sink to the bottom, and I realized that the brain was processing the information to invert the up/down/left/right image transferred to the retina. I have a question about optics and ophthalmology. Does the inversion of the image transferred to the retina depend on the position of the intraocular focal point of the lens of the eye? For example, in people with farsightedness, the focal point is...
