Spectral Lines - What Determines Their Width?
In summary, spectral lines are created when electrons in an atom are excited to higher energies and then fall back to lower energy levels, emitting light in the form of photons. This specific energy/frequency is what causes the line to be characteristic of the given element, and there is a narrow spread in emitted frequencies for each atomic spectral line.
Unredeemed
120
I don't really understand how we observe spectral lines of a particular element and why they are there? Can anyone help?
Thanks.
The spectral lines appear because electrons in atoms are only allowed to occupy certain energy levels that are characteristic of the given element. i.e. Electrons in a given element can only have certain energies. When an atoms electrons are excited to higher energies they eventually fall back down to lower energy levels, giving off their energy as photons (light).
Now, the frequency of a photon given off by one of these electrons is determined by the following:
E=hf
where E is the energy of the photon and f is it's frequency.
Since the electrons are only able to give of specific amounts of energy (the energy differences between two allowed energy levels) the electrons will thus only be able to give off specific frequencies of light, those corresponding to transitions between allowed energy levels. These specific energies/frequencies are different for different elements and are the cause of different spectral lines for different atoms(where each line corresponds to a different frequency or wavelength).
Does this explanation make things any clearer?
E=hf
Understood, thanks a lot, that was a most helpful explanation.
If the emitted photon frequency was specific, i.e. exact, then the position of the photon would be anywhere in the Universe from Heisenberg's Uncertaintity Principle. (delta p * delta x = a constant).
Is there a slight spread in the frequency of the emitted photon in practice?
There is actually a narrow spread or distribution of frequencies for each atomic spectral line. The width of the line is referred to as the natural linewidth, so that the frequency (and hence energy) of emitted photons is not precisely known.
Note, however, that this is NOT due to QM effects.
The linewidth of a spectral line is the inverse of the lifetime of the state; this is a simply a consequence of basic Fourier analysis and the relation between time and frequency: If something is localized in time it has to be delocalized in frequency and vice versa (i.e. short lifetimes give broad frequency distributions); this is sometimes known as the "mathematical uncertainty principle" and has nothing as such to do with physics (it is also important when e.g. designing filters).
1. What are spectral lines?
Spectral lines are specific wavelengths of light that are emitted or absorbed by atoms or molecules. They are like fingerprints that help identify the elements present in a substance.
2. How do spectral lines form?
Spectral lines are formed when electrons in an atom or molecule absorb energy and jump to a higher energy level, or when they release energy and fall back to a lower energy level. This energy is emitted or absorbed in the form of light at specific wavelengths, creating the characteristic spectral lines.
3. Why are spectral lines important in science?
Spectral lines are important because they allow scientists to identify the chemical composition of substances, such as stars, planets, and even our own atmosphere. They also provide insight into the temperature, density, and other physical properties of these objects.
4. How can scientists use spectral lines to study the universe?
Scientists can use spectral lines to study the universe by analyzing the light emitted from celestial objects. This allows them to determine the composition, temperature, and movement of these objects. Spectral lines also provide evidence for the expansion of the universe and the presence of dark matter.
5. What is the significance of the different types of spectral lines?
There are three main types of spectral lines: emission lines, absorption lines, and continuous spectra. Emission lines indicate the presence of a specific element or molecule, while absorption lines indicate the absence of certain wavelengths due to the absorption of light by atoms or molecules. Continuous spectra are produced by hot, dense objects and provide information about the temperature of the object. By analyzing these different types of spectral lines, scientists can learn about the chemical and physical properties of objects in the universe.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
