Speed & Gravity: Equations of Motion & Energy Explained
In summary: There is no "direct" double integral. You can always write position as\vec{r} = \int\int \ddot{r}(t)dt dt(with suitable limits)but the two dt's have to be dealt with carefully. I don't see how you can get to the position from the acceleration directly. But if you want to get to velocity then note that vdv = a ds.It seems as thoughy you treated you assumed \int \frac{d^2r}{dt^2} = \frac{dr}{dt} \int \frac{dr}{dt} which isn't true.
mlazos
49
we know from the equation of motion that
[tex]\frac{d^2r}{dt^2}=a[/tex]
where a is the acceleration
for the gravity field we have
[tex]a=\frac{GM}{r^2}[/tex]
So we get
[tex]\frac{d^2r}{dt^2}=\frac{GM}{r^2}[/tex]
[tex]\frac{(R1^3-R2^3)}{3}\frac{dr}{dt}=GMt[/tex]
[tex]\frac{dr}{dt}=\frac{3GMt}{R1^3-R2^3}[/tex]
[tex]u=\sqrt{\frac{3GMt}{R1^3-R2^3}}[/tex]
If we integrate one time from R1 to R2 shouldn't we get the speed?
Because from the equation og energy we get a different result
[tex]u=\sqrt{2GM}\sqrt{\frac{R1-R2}{R1*R2}}[/tex]
So where am i wrong?
mlazos said:
[tex](R1^3-R2^3)\frac{dr}{dt}=GMt[/tex]
[tex]\frac{dr}{dt}=\frac{GMt}{R1^3-R2^3}[/tex]
QUOTE]
I don't understand how you get the above.
I forgot a 3 and i have put it back
From the equation
[tex]r^2\frac{d^2r}{dt^2}=GM[/tex]
[tex]r^2dr\frac{dr}{dt}=GMdt[/tex]
[tex]\int_a^b r^2dr\frac{dr}{dt}=\int_0^t GMdt[/tex]
where a=R1 and b=R2
From the equation
[tex]r^2dr\frac{d^2r}{d^t}=GMdt[/tex]
You just arbitrarily stick a dr and dt in? Where did they come from?
[tex]\int_a^b r^2dr\frac{d2r}{dt2}=\int_0^t GMdt[/tex]
where a=R1 and b=R2
?? The integral of a product is not just the product of the integrals.
[tex]\int_{R_1}^{R_2} r^2 dr= \frac{R_2^3- R_1^3}{3}[/tex]
and
[tex]\int \frac{d^2r}{dt^2} dt= \frac{dr}{dt}[/tex]
but that is NOT what you have.
You might want to try "quadrature":
[tex]\frac{d^2r}{dt^2}= -\frac{GM}{r^2}[/tex]
Let [itex]v= \frac{dr}{dt}[/itex]. Then
[tex]\frac{d^2r}{dt^2}= \frac{dv}{dt}= \frac{dv}{dr}\frac{dr}{dt}= v\frac{dv}{dr}= -\frac{GM}{r^2}[/tex]
[tex]v dv= -\frac{GM}{r^2}dr[/tex]
[tex]\frac{1}{2}v^2= \frac{GM}{r}+ C[/tex]
[tex]\frac{1}{2}v^2-\frac{GM}{r}= c[/tex]
Which is "conservation of energy": [itex]\frac{1}{2}v^2[/itex] is kinetic energy and [itex]-\frac{GM}{r}[/itex] is potential energy.
Ok bu why with a direct double integral we don't get the same?
why we have to go to the speed and then to find a displacement as a function of R?
Why is wrong?
The dr/dt was a mistake which i corrected
the question is real and is not a trap
Why is wrong?
[tex]
[/tex]
but the two dt's have to be dealt with carefully. I don't see how you can get to the position from the acceleration directly. But if you want to get to velocity then note that [itex]vdv = a ds[/itex].
[tex] \int \frac{d^2r}{dt^2} = \frac{dr}{dt} \int \frac{dr}{dt} [/tex]
which isn't true. The quadrature method suggested above will give a correct general solution, although it's hideous. r(t) = A*(to - t)^2/3 is a solution as well, although it won't fit arbitrary conditions. The general solution requires integrating
which, when done by MATLAB gives a horrendous trascendental equation I couldn't begin to invert for r(t). Good luck with that.
Haha yeah :biggrin:
I'm no expert but isn't there any perturbation method available for a solution (just a wild guess...lets see how wild it is).
1. What is the equation for calculating speed?
The equation for calculating speed is speed = distance / time. This means that to find the speed of something, you divide the distance it has traveled by the time it took to cover that distance.
2. How does gravity affect speed?
Gravity affects speed by pulling objects towards the center of the Earth. This means that objects will accelerate towards the ground at a constant rate, increasing their speed as they fall.
3. What is the equation for calculating the force of gravity?
The equation for calculating the force of gravity is F = G (m1m2 / r^2), where G is the universal gravitational constant, m1 and m2 are the masses of the two objects, and r is the distance between them. This equation shows that the force of gravity is directly proportional to the product of the masses and inversely proportional to the square of the distance between them.
4. How does speed affect an object's kinetic energy?
Speed has a direct effect on an object's kinetic energy. The kinetic energy of an object is equal to half of its mass multiplied by its velocity squared (KE = 1/2 mv^2). This means that as an object's speed increases, its kinetic energy also increases.
5. How are speed and energy related?
Speed and energy are closely related. In physics, energy is defined as the ability to do work. The faster an object is moving, the more work it can do in a given amount of time, thus having a higher energy. Additionally, the energy an object has due to its motion is called kinetic energy, which is directly proportional to its speed squared.
