Speed at which diver enters water
  • Thread starter Thread starter kinganu123
    Speed Water
The discussion focuses on calculating the speed and angle of a diver entering the water after jumping from the edge of a swimming pool. The diver travels 5.7 meters in 0.82 seconds, leading to a calculated speed of 8.04 m/s at a 30-degree angle. Participants emphasize the independence of horizontal and vertical motion, comparing the dive to projectile motion. There is a consensus that assuming the pool's edge is level with the water simplifies the problem. Overall, the conversation highlights the importance of understanding the assumptions in physics problems for accurate calculations.
kinganu123
A diver dives from the edge of a swimming pool and lands in the pool 5.7 m away and 0.82 seconds later.
With what speed did the diver dive? At what angle?
Δx=5.7
t=.82
X and Y are independent
Final answer should be 8.04 m/s at a 30 degree angle
V=V0+at
V2=V02+2aΔx
Δx=V0t+.5at2
Vox=V0cosθ
Voy=V0sinθ
Vox=6.95
After that, I'm stumped
I'm missing two variables in every single equation :(
I think you need a couple more assumptions.
If the edge of the pool is level with the water then the path is a parabola - it's the same question as firing a canonball upward and finding where it lands.
well that makes a LOT of sense
Thanks a bunch! :D
and to why think I was stuck on this for an hour...
the entire time, i was thinking that the water was below the edge of the pool
If it's a diving board and they dived horizontally it would ask you to calculate the height not the angle. If it's a diving board and they jump up you don't have enough info.
After a while you get to spot the questions - it's just practice!
Ya, unless it's specifically stated that there is a difference in height I usually just asume that everything is level in problems like these
