Speed of a photon with wavelength = 500nm?
The speed of all photons is constant at the speed of light, denoted as c, regardless of their wavelength, including one with a wavelength of 500nm. While photons always travel at c in a vacuum, their effective speed can vary when passing through different materials due to interactions like absorption and re-emission. This distinction is important as it clarifies that while c remains constant, the apparent speed can change based on the medium. The discussion also touches on the misconception that c varies, which is corrected by emphasizing that it is the propagation speed in materials that varies, not the speed of light itself. Understanding these principles is crucial for accurately discussing photon behavior in various contexts.
delongk
What is the speed and momentum of a photon with wavelength 500nm?
I found momentum by wavelength = h/p but how do I find velocity?? Please help. Thanks. I don't know how to do it without a mass.
Kristin
All photons travel at c.
- Warren
Well that makes it easy. Thank you tons for clearing that up... something so simple, you think they'd tell you that in the book. Thanks again!
Are you sure the question was about the speed of the photon and not the frequency? Since it seems rather odd to ask about speed, since as chroot said above all photons travel at c.
- Warren
I laughed when I read this at first, but then I stopped laughing when I remembered that c varies. Quiz question -- why?
And then there's the extreme case that came up in a thread recently with the apparatus that stops photons completely. That was weird.:bugeye:
this is not correct. c does not vary. the apparent speed of photon propagation can vary in materials.
Good point. I misspoke in an effort to be brief. c is indeed a constant, but the speed of photons depends on the medium. Thanks for catching my error. :blushing:
Actually, I think even that's oversimplifying.
The speed of photons is always c. However, they do not always "make headway" equivalent to c when in materials. (the photons lose headway when absorbed and re-emitted).
Indeed, all photons travel at c; however, as has been said previsouly their rate of propogation can vary (depending on the medium). There is a related thread https://www.physicsforums.com/showthread.php?t=128221&highlight=photons+speed".
