Speed of a Sneeze: Solve Homework Statement
  • Thread starter Goatsenator
  • Tags
    Speed
In summary, the conversation discusses the process of coughing and how it expels air at high speed through the trachea and upper bronchi. The steps of this process include breathing in a large amount of air, trapping it by closing the glottis, increasing air pressure, partially collapsing the trachea and upper bronchi, and then expelling the air through the pathway by reopening the glottis. The question posed is how the airspeed through the trachea compares to the speed of sound, given different trachea diameters. The equation used to solve this problem is volume flow rate = (area)(velocity) and the answer is obtained by dividing the volume flow rate by the speed of sound (343 m/s
Goatsenator
When you cough, you expel air at high speed through the trachea and upper bronchi so that the air will remove excess mucus lining the pathway. You produce the high speed by this procedure: You breathe in a large amount of air, trap it by closing the glottis (the narrow opening in the larynx), increase the air pressure by contracting the lungs, partially collapse the trachea and upper bronchi to narrow the pathway, and then expel the air through the pathway by suddenly reopening the glottis. Assume that during the expulsion the volume flow rate is 5.3 x 10-3 m3/s. What multiple of the speed of sound xs (= 343 m/s) is the airspeed through the trachea if the trachea diameter (a) remains its normal value of 19 mm and (b) contracts to 7.8 mm?
2. Homework Equations / Solution Attempt
I applied the definition of volume flow rate = (area)(velocity) then divided that answer by 343 m/s to get the ratio but it says that it's wrong.
What was the answer?
Have you tried working backwards? it might help ; )
1. What is the average speed of a sneeze?
The average speed of a sneeze is around 100 miles per hour, but it can vary depending on the individual and the force behind the sneeze.
2. How is the speed of a sneeze calculated?
The speed of a sneeze can be calculated by dividing the distance traveled by the time it takes to travel that distance. This can be measured using high-speed cameras or other specialized equipment.
3. Can the speed of a sneeze be faster than the speed of sound?
No, the speed of sound is around 767 miles per hour, which is much faster than the average speed of a sneeze. However, some sneezes may reach supersonic speeds, but this is rare and not the norm.
4. Does the speed of a sneeze change depending on the environment?
Yes, the speed of a sneeze can be affected by factors such as air resistance and humidity in the environment. For example, a sneeze may travel faster in a dry environment compared to a humid one.
5. Why is it important to know the speed of a sneeze?
Knowing the speed of a sneeze can help in understanding the spread of diseases and how to prevent them. It can also be useful in designing air filtration systems and predicting the transmission of airborne illnesses.
  • Mechanical Engineering
22K
