Speed of an electron in an electric field - trying to find my error.
The discussion centers on calculating the final speed of an electron released from rest between two positive point charges, specifically 3.45 nC and 1.85 nC, separated by 50.0 cm. The user attempted to apply the energy conservation equation, Ek(f) + U(f) = Ek(i) + U(i), but encountered a negative value under the square root, indicating a calculation error. The primary issue identified was the incorrect treatment of the electron's negative charge in the potential energy calculations. The corrected final speed of the electron is determined to be 7.53 x 106 m/s.
  • Understanding of electrostatics and Coulomb's law
  • Familiarity with kinetic and potential energy equations
  • Knowledge of conservation of energy principles
  • Basic algebra for solving equations
  • Review the concept of electric potential energy in electric fields
  • Learn about the implications of charge polarity in energy calculations
  • Study the derivation and application of the conservation of energy in electrostatics
  • Explore advanced topics in particle motion in electric fields
Students in physics, particularly those studying electromagnetism, as well as educators and anyone interested in understanding the dynamics of charged particles in electric fields.
rowkem
Two stationary positive point charges, charge 1 of magnitude 3.45 nC and charge 2 of magnitude 1.85 nC, are separated by a distance of 50.0 cm. An electron is released from rest at the point midway between the two charges, and it moves along the line connecting the two charges.
What is the speed v(final) of the electron when it is 10.0 cm from charge 1?
Ek= (mv^2)/2
U= (k(q1q2))/r
I used the following equation:
Ek(f)+U(f) = Ek(i)+U(i)
(mv(f)^2)/2 + (k(q1q2))/r = (mv(i)^2)/2 + (k(q1q2))/r
(9.1x10^-31)(vf)^2)/2 + (((9x10^9)(3.45nC)(1.6x10^-19))/0.10m) + (9x10^9)(1.85nC)(1.6x10^-19))/0.40m) = (((9x10^9)(3.45nC)(1.6x10^-19))/0.25m) + (9x10^9)(1.85nC)(1.6x10^-19))/0.25m)
(9.1x10^-31)(vf)^2)/2 + 5.6x10^-17 = 3.0 x 10^-17
(9.1x10^-31)(vf)^2)/2 = -2.6 x 10^-17
Then my issue: I end up needing to take the square root of a negative number...yah.
If someone could please point me to the error I've made, it would be appreciated. I'm iffy on my "Ek(f)+U(f) = Ek(i)+U(i)". Did I use the correct equations? Please help, thanks.
You are releasing an electron which carries a negative charge. It looks like you haven't carried that into the calculation of U correctly.
That would do it. I end up getting 7.53x10^6 m/s. Seems high - thoughts before I submit?
I didn't follow your calculation, but off the cuff with mass at 10-31 a little change in potential should go a long way.
14K
