Speed of Electrons and energy level
Electrons in higher energy levels exhibit increased speed due to the relationship between linear velocity and radius in circular motion. While centripetal force is inversely proportional to the radius squared, the need for constant centripetal acceleration means that as the radius increases, the speed must also increase. The discussion references Bohr's model, which quantizes energy levels and explains that electrons lose energy and move closer to the nucleus, resulting in lower velocity. The analogy of v = r * omega is highlighted to illustrate that with constant angular velocity, linear velocity must increase at larger radii. The conversation concludes by questioning the forms of energy associated with orbiting electrons.
Werg22
Do electrons on higher energy levels have increased speed? This is confusing because if we look at it considering a centripetal force inversly proportional to the radius squared, the speed decreases. However since it's on a higher energy level, dosen't that mean the speed actually increases?
Well you can think of it like this. v^2/r equals a constant, if r increases v must also increase to maintain the same centripetal acceleration. If youre up to rotational motion, then you know the formula v=omega*r. If angular velocity is the same, than as you go farther out, linear velocity must be greater to catch up to the other electrons.
Bohr realized this and thought that if electrons were giving off light, they were losing energy and must be moving closer and closer to the nucleus with lower and lower velocity until they collided with it. He resolved this with the Bohr model and quantized energy levels
Why should the centripetal force be constant? Isn't proportional to the inverse of the radius squared?
It is not constant I should think. If you have covered electric fields you would know and yes you are right that it is inversely proportional to r. The v=r*omega analogy is correct though.
What forms of energy does the orbiting electron have?
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
