PAllen
- 2,543
Consider two comoving inertial world lines in special relativity. Consider just standard inertial coordinates. This 'physical distance' so defined, between these two bodies, can take any value in (0,L] , where L is the proper distance between them. Note, that in all such coordinates this so called physical distance is constant in coordinate time.cianfa72 said:Here with "physical distance" between the two spatial locations I understand the following:
Consider the timelike worldlines of the 'things' emitting and receiving the light ray, respectively. They cross in two points (events) the spacelike surfaces of constant coordinate time ##\tau## -- in the chosen coordinate system. Then take the spacelike curve on each of these spacelike surfaces joining the points of intersection above.
The spacetime 'length' along these spacelike curves is required to be constant in coordinate time (in other words on each of the above spacelike surfaces) and it is actually the 'physical distance' we are talking about.
