Speed of light of different wavelengths in medium
The discussion centers around the speed of light of different wavelengths in a medium, specifically how to calculate the time difference between red and blue light exiting a piece of glass. Participants explore the relationship between the speed of light, wavelength, and refractive index, considering various equations and models.
  • One participant notes that while the speed of light in a vacuum is constant, it varies with wavelength in a medium, leading to different exit times for red and blue light.
  • Another participant states that the variation of the index of refraction with wavelength must be determined experimentally, suggesting the use of dispersion curves or empirical formulas.
  • A participant introduces the wave number and discusses relationships between velocities and wavelengths when light transitions between media.
  • There is a mathematical formulation presented for calculating the time taken for red and blue light to pass through the medium, but it relies on knowing the velocity of either color.
  • Some participants suggest using Cauchy's or Sellmeier equations to find the relationship between refractive index and wavelength, while others argue that no general equation exists for all materials.
  • Concerns are raised about the assumption that velocity is linearly related to wavelength, with a participant questioning the validity of this assumption.
  • Another participant disputes the claim that the frequencies of red and blue light are the same in a medium, asserting that this affects the relationship between their velocities and wavelengths.
  • It is suggested that specific data related to the medium in question is necessary to understand optical dispersion.
Participants express differing views on the relationships between wavelength, velocity, and refractive index. There is no consensus on the assumptions made regarding the velocities of different wavelengths or the applicability of certain equations. The discussion remains unresolved with multiple competing perspectives.
Limitations include the dependence on specific material properties for refractive index and the lack of a universal equation for all wavelengths. The discussion also highlights the need for empirical data to accurately describe optical dispersion.
LmdL
Hello,
As we all know, speed of light of different wavelengths (let's say red and blue) in vacuum is same. However, in medium (like glass) it's different and depends on a wavelength and a refractive index.
Let's say we send a short pulse of white light incident into a piece of glass (of length L). Red light will come out of it first and a blue last. But how can I calculate the time difference (or a displacement) of red and blue light at the exit from the glass?
I know the velocity in medium is v=c/n, where c is constant (speed of light in vacuum) and n is a refractive index of the medium. But how can I get a relation between v (speed of light in medium) and its wavelength? I guess I need to connect between refractive index n and a wavelength of the light first. Thought to use a Cauchy's equation (or a Sellmeier equation), but maybe there is a easier way?
Thanks!
Science news on Phys.org
I am afraid not. The variation of the index of refraction with wavelength is determined experimentally. Either you look at a dispersion curve, use a table or an empirical formula.
wave number k is 2pi/wavelength ...also k1/k2= lamda2/lamda1= velocity2/velocity1 ...where 1 and 2 represent medium 1 and 2. These are simply the results of applying the boundary conditions to a wave passing from one medium to another. Since red and blue light cover the same distance through slab, L ...knowing a relationship between their velocities should tell you the difference between their time of arrival just outside the slab.
the relation ship between their velocities inside glass can be found out from their respective wavelengths...since frequency stays constant when light passes through any medium, frequency of red= frequency of blue , or velocity of red/lamda of red = velocity of blue/lamda of blue.
You are right, but I still need their velocity to know the difference between exit times.
Red light velocity:
[tex]\frac{v_{R}}{\lambda_{R}}=\frac{v_{B}}{\lambda_{B}}\rightarrow v_{R}=\frac{\lambda_{R}}{\lambda_{B}}v_{B}[/tex]
Time taken to red light to pass:
[tex]t_{R}=\frac{L}{v_{R}}=\frac{\lambda_{B}}{\lambda_{R}}\frac{L}{v_{B}}[/tex]
Time taken to blut light to pass:
[tex]t_{B}=\frac{L}{v_{B}}[/tex]
Exit time difference:
[tex]\Delta t=t_{B}-t_{R}=\left (\frac{L}{v_{B}}-\frac{\lambda_{B}}{\lambda_{R}}\frac{L}{v_{B}} \right )=\left (1-\frac{\lambda_{B}}{\lambda_{R}} \right )\frac{L}{v_{B}}[/tex]
So, I still need velocity of either blue or red light.
Well, you indeed need to know the dependency between refractive index and wavelength to get ##v(\lambda)## for different colors. However, there is no such a thing as a general equation describing refractive index as a function of wavelength. The function ##n(\lambda)## is material dependent, the most common way is to use Sellmeier equation. There is no easier than using this equation.
Where does that equation come from? You cannot simply assume that the velocity is linear with respect to wavelength.
That's what akaaty suggested, and I showed that I still need a velocity of either red or blue light (from Cauchy/Sellmeyer).
In akaaty's formula ##v_1## and ##v_2## are defined to be the velocities at two different medium, they do not correspond to velocities for waves of different wavelengths. Moreover about the formula itself, I don't think that represents a correct relationship between the velocities of light in different media for this relationship is given by
\frac{v_1}{v_2} = \frac{n(\lambda_2)}{n(\lambda_1)}
I guess he/she was taking an analogy with a mechanical waves in a boundary between two media, and that the velocities he was using are the oscillation velocities.
No, this is wrong. The frequencies of the red and blue light are not the same. And this is true in any medium. So the relationship between wavelengths and velocities is not valid.
It is true that the frequency does not change when light passes through a medium but this does not help you to find the speed in the medium.
The dependence of velocity on frequency is a property of the medium, you cannot find it from these manipulations.
Correct, you have to look for data related to the specific medium that you're interested in. Try Googling for phrases similar to "optical dispersion in xxx".
  • · Replies 25 ·
11K
  • · Replies 207 ·
16K
  • · Replies 52 ·
15K
