Light as a Constant: Examining the Paradox
Light is a constant for all observers due to the fundamental principles of physics, particularly as demonstrated by the Michelson-Morley experiment, which showed that light's speed remains unchanged regardless of the Earth's motion. Unlike everyday objects, such as a baseball, which have velocities that can be added based on the observer's frame of reference, light's speed is invariant and does not follow this additive behavior. The relativistic formula for combining velocities reveals that even at high speeds, the perceived speed of light remains constant at approximately 299,792 kilometers per second. This phenomenon is a cornerstone of Einstein's theory of relativity, which has been confirmed by multiple experiments, including the Kennedy-Thorndike and Ives-Stilwell experiments. The constancy of light is a fundamental aspect of our universe, reflecting the underlying laws of physics.
matt4584
How can light be a constant for any observer? I understand how it fits into equations and what not, but how can it be a constant. If I throw a baseball forward at 10m/s in a train going 40m/s. I perceive it as 10, an observer on the ground would perceive it as 50. Why doesn't the same apply to light? Is there anything else it doesn't apply to?
Science news on Phys.org
You are mistaken about the baseball example: in fact the observer on the ground measures the speed of the baseball to be very slightly less than 50m/s.
If the speed of the train is ##u## and the ball is thrown at speed ##v##, its speed relative to the ground will not be ##u+v##, it will be ##(u+v)/(1+\frac{uv}{c^2})##. This formula has been verified by experiment.
It would be a good exercise to try calculating this for the speeds in your example; you will quickly see why in daily life we never notice that ##(u+v)## is not exactly correct. It's also worth seeing what happens when you set ##v=c##, shining a light forward in the moving train.
Because that's the way the universe works. None of us built it. We just found it this way. Cool, isn't it?
Likes John Park, XZ923 and davenn
matt4584 the classic observation of this is the Michelson Morley experiment where light beams were sent parallel to the rotation of the surface Earth which is also pretty close to the direction of motion of the Earth about the sun and normal to the direction of rotation of the Earth and its direction of rotation about the sun. The velocity of light is measured to be the same in both directions, which it would not be if a medium through which the Earth moved in its motion about the sum had existed. (See https://en.wikipedia.org/wiki/Michelson–Morley_experiment) for more detail. The Kennedy-Thorndike experiment (https://en.wikipedia.org/wiki/Kennedy–Thorndike_experiment) directly confirms that the speed of light is constant and with the Ives Stilwell experiment (https://en.wikipedia.org/wiki/Ives–Stilwell_experiment) confirms the Lorentz transformation of special relativity.
