Speed of pendulum at certain angles
The discussion centers on calculating the speed of a pendulum at 30 degrees after being dropped from 140 degrees, emphasizing the importance of energy conservation principles. The approach involves using gravitational potential energy and kinetic energy equations to determine speed, with a focus on the change in potential energy as the pendulum moves. It is noted that the mass of the pendulum is irrelevant in this calculation, but the length of the pendulum (L) is crucial for accurate results. A calculation provided yields a speed of approximately 3.38 m/s, but it is highlighted that the length must be included in the equations for a complete understanding. The conversation underscores the need for clarity on the pendulum's setup, particularly regarding whether it uses a solid rod or string.
Bronzer
I'm having no problem finding the maximum speed of a pendulum but I'm not sure when I move its start point and measure point.
I would like to know the speed of a pendulum at 30 degrees that has been dropped at 140 Degrees. I'm just giving some numbers to explain that it is above the horizontal and doesn't pass through equilibrium.
Any thought's on this would be useful.
Thanks.
You need to give more background. Where are you in school? What math have you taken?
Out of school, AS level Math.
This isn't homework, just a practical problem I'm trying to get my head around.
All of my usual point of calls don't like pendulums that go above the horizontal (I guess GCSE assumes it's made of string) and I can only find equations for Vmax.
As with many such problems, you can either approach this problem by considering the Forces involved or by considering the Energy transfer. The Maths is pretty straightforward if you work out the change in gravitational potential energy and the corresponding gain in Kinetic Energy. That is an enormous clue!
That assumes the pendulum uses a solid rod (like most practical pendulums, aamof) If you want to assume string then you would have to know an awful lot more about the set up - the shape of the bob, for instance.
Likes anorlunda
Right, so if I take energy of pendulum equation as
PE = mgL(1 – COS θ)
Mass should be irrelevant for this(?)
9.81*1*(1-cos(140))=13.2
9.81*1*(1-cos(30))=7.5
= 5.7j change
KE=1/2mv^2
2KE=mv^2
sqrt(2KE)=mv
Ignore M, so that V = sqrt(2*5.7)
=3.38m/s
Is that looking ok?
You lost L somewhere? But that's the sort of thing I meant.
Yeah L=1, sorry.
By choosing a magic number for L you have thrown away an important part of the relationship. The speed cannot be independent of L, can it, so you should include the length even if you later happen to give it a value of 1m, 1cm, 1km.
