Speeds of tennis balls after collision
In a discussion about a perfectly elastic collision between two tennis balls, a 0.0600 kg ball moving at 2.50 m/s collides head-on with a 0.0900 kg ball moving at 1.00 m/s. Participants highlight the need for two key equations: conservation of momentum and the relative velocity equation. The initial attempt to solve the problem involved confusion over the number of variables and equations needed. After some back-and-forth, it was clarified that the masses remain constant, simplifying the calculations. The conversation emphasizes the importance of correctly applying physics principles to find the final speeds and directions of both balls after the collision.
balletgirl
A 0.0600 kg tennis ball, moving with a speed of 2.50 m/s, has a head-on collision with a 0.0900 kg ball initially moving away from it at a speed of 1.00 m/s. Assuming a perfectly elastic collision, what is the speed and direction of each ball after the collision?
m1v1+m2v2 = m1v1'+m2v2'
with the given, I know that
m1= .06 kg
m2=.09 kg
v1= 2.5 m/s
v2= 1.0 m/s
after this, I don't know where to start?
Hi balletgirl
Plug all the data to the equation you wrote and you lack one more equation, which is V1-V2=V2' - V1'
Okay so I do 2.5-1.0= V2'-V1'. I don't understand how you find those final numbers.
.06kg(2.5m/s) + (.09kg)(1.0m/s) = m1v1'+m2v2'
You have two equations and two variables so just use elimination or substitution
I don't understand the concept.
I thought I was solving for four variables: m1' v1' m2' and v2'
Anyways I got to .135=m1v1'+m2v2'
1.5= V2'-V1'
it didn't work out when I tried using elimination or substitution
Okay just realized a dumb mistake. The mass will stay the same. This will make everything a lot easier for me.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
