Finding the Relative Density of a Floating Sphere in Liquid
A hollow spherical shell with a 1-meter external diameter and a thickness of 0.2 meters floats in a liquid, with half its volume submerged, and has a given relative density of 1.5. The density of the liquid is calculated to be 1500 kg/m³. Using the principle of buoyancy, the equation Vρg = Weight is applied to find the relative density of the shell material. The calculations reveal that the relative density of the shell material is approximately 0.96. The discussion highlights the importance of correctly applying the buoyancy equation, noting a missing factor of 4/3 in the calculations.
Darth Frodo
A hollow spherical shell of external diameter of 1 metre and uniform thickness of 0.2m floats in a liquid with half its volume immersed. If the relative density is 1.5 find t 2 decimal places the relative density of the material of the shell.
Buoyancy = Vρg = Weight
Relative density of liquid = 1.5
Density of liquid = 1500
Since it floats Buoyancy = Weight
Vρg = Vρg
( \frac{2}{3}\pi ) (1500g) = [ \frac{4}{3} \pi - \frac{4}{3} \pi (0.8^{3}) ) ] Xg
1000\pi g = \frac{244}{375} \pi Xg
1000 = \frac{244}{375} X
X = 1536.8
Therefore relative density = 1.5
Answer = 0.96
4/3 is missing from the right-hand side. It should be 1000=(4/3)*(244/375)*X.
ehild
