Spherical Harmonics/Angular Momentum
  • Thread starter Thread starter atomicpedals
    Momentum Spherical
atomicpedals
Given that Lz(x+iy)m=m\hbar(x+iy)m. Show that L+=(x+iy)m.
2. The attempt at a solution
I'm probably grasping at straws here, but when I see the expression for Lz I instantly go to Lz|lm>=m\hbar|lm>. This then leads me to suspect that |lm>=(x+iy)m. Is this correct, and how on Earth does it get me any closer to what I want to show for the raising operator?
Not exactly. What \hat{L}_z(x+iy)^m=\hbar m(x+iy)^m tells you is that (x+iy)^m \propto \langle x,y | l~m \rangle. You need to keep the distinction between kets and the representation of the ket in some basis. Writing (x+iy)^m = |l~m\rangle is, at best, a terrible abuse of notation.
I have no idea what \hat{L}_+ = (x+iy)^m is supposed to mean.
To solve this, I first used the units to work out that a= m* a/m, i.e. t=z/λ. This would allow you to determine the time duration within an interval section by section and then add this to the previous ones to obtain the age of the respective layer. However, this would require a constant thickness per year for each interval. However, since this is most likely not the case, my next consideration was that the age must be the integral of a 1/λ(z) function, which I cannot model.
