Spherical mirror radius of curvature
The discussion revolves around calculating the radius of curvature of a spherical mirror used by a dentist to examine a tooth. The object distance (p) is 1.13 cm, and the image distance (q) is -10.8 cm, leading to the equation 1/p + 1/q = 1/f. The attempted solution incorrectly calculates the subtraction of fractions, resulting in an erroneous value for the radius of curvature. The correct approach requires careful handling of the fractions to avoid mistakes in the final answer.
roam
A dentist uses a spherical mirror to examine a tooth. The tooth is 1.13 cm in front of the mirror, and the image is formed 10.8 cm behind the mirror. Determine the mirror's radius of curvature.
1/p+1/q=1/f
f=R/2
Since the object is in front of the mirror, p > 0. With the image behind the mirror q < 0. So the radius of curvature is
\frac{2}{R}=\frac{1}{p} + \frac{1}{q} = \frac{1}{1.13} - \frac{1}{10.8} = \frac{10.8-1.13}{10.8}
So R = 2 \frac{10.8}{9.67} = 2.233
Why is my answer is wrong? I think I used the correct equations. I tried the same question with different numbers and the computer still marks my answer wrong. Any explanation would be appreciated.
\frac{1}{1.13}-\frac{1}{10.8}\neq\frac{10.8-1.13}{10.8}
1/p+1/q=1/f
f=R/2
You mucked up the subtraction of two fractions - in particular, the denominator.
