I Spin conservation in the Dirac equation
chingel
Here I am considering the one particle free Dirac equation. As is known the spin operator does not commute with the Hamiltonian. However, the solutions to the Dirac equation have a constant spinor term and only an overall phase factor which depends on time. So as the solution evolves in time, surely the spin operator will act on the spinor part the same way at any moment.
How to reconcile this with the fact that the spin operator doesn't commute with the Hamiltonian and it is often said that spin is not conserved for the Dirac particle? I mean the solutions are even named spin up and spin down. I know if p is not zero the solutions aren't eigenvectors of the spin operator, but still the spinor is constant, so why isn't spin constant? In the basis of the spin operator the solution has constant components, except for overall phase.
Which spin operator are you talking about? And which Hamiltonian?
The Hamiltonian I am considering is $$H=\vec{\alpha} \cdot \vec{p} + \beta m,$$ where ##\alpha^i = \gamma^0\gamma^i##, ##\beta=\gamma^0##, ##p_k = i\partial_k##, ##\vec{p} = -i\vec{\partial}##, so that ##i\partial_t \psi=H\psi## gives just the Dirac equation ##(i\gamma^\mu\partial_\mu -m )\psi=0## multiplied by ##\gamma^0##. For the spin operator $$\vec{\Sigma} =
\begin{bmatrix}
\vec{\sigma} & 0 \\
0 & \vec{\sigma} \\
\end{bmatrix}.$$
An example of the calculation for the commutator ##[H, \vec{\Sigma}]## is on slides 90, 91, 92 of this link: https://www.hep.phy.cam.ac.uk/~thomson/partIIIparticles/handouts/Handout_2_2011.pdf
However, if I look at the solutions on slide 75 (eigenvectors of H), I don't understand how anything changes over time in the way the spin operator acts on the states, the spinors are constant with just an overall phase and the components of the spinor in the eigenbasis of the spin operator should stay the same, up to an overall phase. Looking directly at the solution, why isn't spin conserved?
Thank you for the link. There they calculate that the expectation value of the change of the spin or angular momentum is zero. While the expectation value does not change, they still seem to say that Zitterbewegung causes the spin to change in some sense. I still don't quite understand why or how, maybe someone can explain it to me.
To maybe make my question clearer, if I have the spin operator ##\vec{\Sigma} = \begin{bmatrix} \vec{\sigma} & 0 \\ 0 & \vec{\sigma} \end{bmatrix}## and a solution of the Dirac equation ##u(p) = e^{-ip_\mu x^\mu} \sqrt{E+m} \begin{bmatrix} 1 \\ 0 \\ \frac{p_z}{E+m} \\ \frac{p_x+ip_y}{E+m} \end{bmatrix}##, then if at all and why does the spin of this solution change over time, and if it is Zitterbewegung then how exactly the Zitterbewegung works here to change the spin?
You are clever and will figure out if the following is right or wrong.
At some point in the derivation of the time derivative of an expectation value don't we need to assume that ψ goes to zero at infinity? If so you need to work with a localized wave packet which contains both positive and negative energies? If that is the case then it is easier to see how interference between the positive and negative components give rise to conservation of only the total angular momentum, L+S?
Interesting question, I hope you get an answer.
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
Is it possible, and fruitful, to use certain conceptual and technical tools from effective field theory (coarse-graining/integrating-out, power-counting, matching, RG) to think about the relationship between the fundamental (quantum) and the emergent (classical), both to account for the quasi-autonomy of the classical level and to quantify residual quantum corrections? By “emergent,” I mean the following: after integrating out fast/irrelevant quantum degrees of freedom (high-energy modes...
