Spinning pseudo gravity problems
  • Thread starter Thread starter Prasanna Suman
    Gravity Spinning
Spinning pseudogravity does share similarities with centrifuges, particularly in how they can separate materials based on density. In a centrifuge, lighter gases rise while heavier gases settle, a principle that also applies to pseudogravity environments. However, the design differences are significant; centrifuges are typically long tubes, whereas pseudogravity devices can have varied shapes. The discussion highlights the vortex tube as an example of a device that separates gases without moving parts, utilizing high rotational speeds. Overall, the principles of separation in both systems are fundamentally similar, but their applications and designs differ.
Prasanna Suman
Is a spinning pseudogravity similar to centrifuge in any way.
If yes, then contents in it (like air) should also separate to layers (like H2 at top and heavier gases at bottom).
Is this correct? Could you help me with your ideas?
Basically the answer is yes. The main differences are quantitative, i.e. a centrifuge usually is a long tube, while psuedogravity devices would have a much different shape,
I believe that is why for Uranium extraction they use centrifuges...
Check this out:
Excerpt from http://en.wikipedia.org/wiki/Vortex_tube
The vortex tube, also known as the Ranque-Hilsch vortex tube, is a mechanical device that separates gas into hot and cold streams. It has no moving parts. Pressurized gas is injected into a swirl chamber and accelerates to a high rate of rotation (over 1,000,000 rpm). The gas is split into two streams, one giving kinetic energy to the other, and resulting in separate flows of hot and cold gases.
comparing a flat solar panel of area 2π r² and a hemisphere of the same area, the hemispherical solar panel would only occupy the area π r² of while the flat panel would occupy an entire 2π r² of land. wouldn't the hemispherical version have the same area of panel exposed to the sun, occupy less land space and can therefore increase the number of panels one land can have fitted? this would increase the power output proportionally as well. when I searched it up I wasn't satisfied with...
