C/C++ How to Create a Spiralling Algorithm in C++ for Printing Patterns
  • Thread starter Thread starter ron_jay
    Algorithm C++
To create a spiraling algorithm in C++ for printing a specific pattern, start by using a 2D array initialized to zero. Begin filling the array from the center, employing loops to manage the direction of movement as you spiral outward. The algorithm requires careful handling of loop counters to ensure the correct placement of numbers, especially when transitioning between layers. Recursion can be utilized to simplify the process, allowing for dynamic adjustment of axes as the pattern expands. It's important to account for both odd and even dimensions of the array to maintain the correct structure.
ron_jay
Hey, I got an assignment to write and algorithm in C++ to print this pattern:
35 34 33 32 31 30
16 15 14 13 12 29
17 04 03 02 11 28
18 05 00 01 10 27
19 06 07 08 09 26
20 21 22 23 24 25
As you can see, the number starts near the center and spirals out... I am stumped. Any help?
Technology news on Phys.org
Simple way for small size is to create a 2d array and fill it in starting from the centre (just need a couple of loops) and then print it.
Generating one line-by-line for an arbitrary size isn't too hard but requires thinking about the loop counters a bit!
This one is a little tricky because the numbering starts from the center. I have already figured out how to do this when the numbering starts from the top left hand corner (recursion) using
"virtual motion analogy" (that's what I like to call it).However,looping with for or while is clumsy. Recursion should solve it elegantly. One can assume the array matrix as a 2D "field" and set them to 0. By, recursion, we can then set the up, down, left and right freedom of movement. However, this is the part which is slippery...how do the axes change to suit the situation? Its like a virtual loop that keeps on depositing a solid layer around it as it rotates on its outer periphery being pulled by the central force - just an analogy...if this could be interpreted in the terms of the matrix...
Use an offset value for the center, in this case it's 3,3 (using y,x as index order)
Then the starting relative index will be -1,-1, followed by -1,+1, +1,+1, +1,-1.
Each time the index pattern is +n, -n, your at end of the current box, and ready to start the next box.
Don't forget to handle the case where the size of the array is an odd number of columns and rows.
You start at the middle, go right, fill in the 8 elements counter clockwise, then step out to the right
again.
Dear Peeps I have posted a few questions about programing on this sectio of the PF forum. I want to ask you veterans how you folks learn program in assembly and about computer architecture for the x86 family. In addition to finish learning C, I am also reading the book From bits to Gates to C and Beyond. In the book, it uses the mini LC3 assembly language. I also have books on assembly programming and computer architecture. The few famous ones i have are Computer Organization and...
What percentage of programmers have learned to touch type? Have you? Do you think it's important, not just for programming, but for more-than-casual computer users generally? ChatGPT didn't have much on it ("Research indicates that less than 20% of people can touch type fluently, with many relying on the hunt-and-peck method for typing ."). 'Hunt-and-peck method' made me smile. It added, "For programmers, touch typing is a valuable skill that can enhance speed, accuracy, and focus. While...
I had a Microsoft Technical interview this past Friday, the question I was asked was this : How do you find the middle value for a dataset that is too big to fit in RAM? I was not able to figure this out during the interview, but I have been look in this all weekend and I read something online that said it can be done at O(N) using something called the counting sort histogram algorithm ( I did not learn that in my advanced data structures and algorithms class). I have watched some youtube...
