Splitting fractional expression into real/imaginary parts
Millertron
Hi guys, I'm having a bit of trouble splitting the RHS of the following expression into real and imaginary parts:
(χ'+iχ")/A = \frac{1}{ω-ω_{0}-iγ/2}
(It's to find expressions for absorption coefficient and index of refraction, but that's irrelevant).
I've defined a = ω-ω_{0} and b = γ/2 for simplicity, and am looking for the form given by Wolfram under 'Alternate form assuming a and b are real', as this has a clear real and imaginary part. So far I've got to
= \frac{1}{a-ib}
= \frac{a-ib}{(a-ib)^{2}}
= \frac{a}{(a-ib)^{2}} - \frac{ib}{(a-ib)^{2}}
only when I expand the squared brackets in each denominator I get (a-ib)^{2}=a^{2}-b^{2}-2iab, which is no good as I need to remove the i's in the denominator.
I know it boils down to a simple algebra/complex nos question but I've been working on this problem for so long that my brain is ceasing to function. Any help is much appreciated!
the trick is to multiply by the complex conjugate to get a real denominator
\frac{1}{a-ib}= \frac{1}{a-ib}\frac{a+ib}{a+ib}= <br /> \frac{a+ib}{a^2+b^2}<br />
\displaystyle=\frac{a}{a^2+b^2}+\frac{b}{a^2+b^2}i
Of course! Definitely should've known this, thanks a lot guys!
no worries, one way to remember is that mulipllying by a complex congujate gives a you a magnitude, which is always real
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
