Spontaneous Symmetry breaking,phase factor
krishna mohan
Book: Maggiore-A modern Introduction to QFT
Section:11.1
He says that if a symmetry transformation multiplies the vacuum state by a constant phase factor only, the symmetry is not broken..
Section:11.2
U(1) symmetry is spontaneously broken...multiplication by exp(i theta) takes the vacuum state to another state on the circle of minima..
But isn't this multiplication by a phase factor? How can you reconcile this with the statement in the previous section?
The first case probably refers to the vacuum state, while the second case refers to a change in the vacuum expectation value when you go to the new vacuum state. In QM, a state multiplied by a phase factor is equivalent to itself.
Let's take the example of a complex scalar field with a U(1) symmetry. Call the corresponding conserved charge Q. Then the unitary symmetry-transformation operator takes the form U(\alpha) = \exp(i\alpha Q).
Now, if the symmetry is unbroken, the vacuum is unique; call it |0\rangle. It is an eigenstate of Q with some eigenvalue, call it Q_0. Usually, we choose to shift Q by a constant so that Q_0=0, but it's not strictly necessary. In general, then,
U(\alpha)|0\rangle = \exp(i\alpha Q_0)|0\rangle.
Now, if the symmetry is broken, there is a family of vacuum states labeled by an angle; call the angle \theta, and call the corresponding vacuum state |\theta\rangle. Now we have
U(\alpha)|\theta\rangle = |\theta{+}\alpha\rangle.
Another way to answer the question is to note that under infinitismal group transformation \phi_{k}(x) changes as U^{\dagger}(\theta) \phi_{k}(x) U(\theta)=-i \theta^{a}T^{a}_{kj}\phi_{j} where T^{a}_{kj} is a generator of the group. So taking the case of U(1), the field under transformation is: \phi(x)-i \theta\phi(x) =\phi(x)(e^{-i \theta}). Therefore the vacuum expectation value of that field changes by that phase factor. If the vacuum expectation value changes by that phase factor, then U(\theta)=e^{-iQ \theta} operated on the vacuum |0> must be a different state since looked at it from another way, <0|U^{\dagger}(\theta) \phi(x) U(\theta)|0>=<0' | \phi(x) |0'> != <0| \phi(x) |0> where != means not equal, implying |0'>=e^{-iQ\theta}|0> is not equal to |0>.
What's fascinating is that no mention of SSB has been mentioned in the analysis! However, if the vacuum expectation value is zero, then |0> can equal |0'>, as they would both have the same expectation value, namely 0. But they still don't have to be the same! Obviously if the expectation value of two states is different, then the two states are different. But if the expectation value of two states is the same, then they still could be different.
However, even if the vacuum is not unique, if the expectation value is zero in all the vacuums, then this doesn't change calculations. But technically, they could be different vacuums. At least I think.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
If we release an electron around a positively charged sphere, the initial state of electron is a linear combination of Hydrogen-like states. According to quantum mechanics, evolution of time would not change this initial state because the potential is time independent. However, classically we expect the electron to collide with the sphere. So, it seems that the quantum and classics predict different behaviours!
