Spring constant, should be easy?
3 replies · 4K views · last reply
Th3Proj3ct
A spring is suspended vertically parallel to a meterstick. When a 170-g mass is attached to the bottom of the spring, the spring stretches until its bottom is adjacent to the 80-cm mark on the meterstick. When a 760-g mass is then used to replace the 170-g mass, the bottom of the spring is measured to be at the 30-cm mark. Based on these measurements, the value of the spring constant is
k=mg/x
Seemed simple enough, (0.17*9.8)/.2 = 8.33 N/m
then (0.76*9.8)/.7=10.64 N/m
But neither of these are correct, and if i take the sum of the masses and distance i get:
(.93*9.8)/0.9=10.126~
None of these can possibly be the correct answer.. and I am sort of lost =/
New question: A spring is suspended vertically parallel to a meterstick. When a 130-g mass is attached to the bottom of the spring, the spring stretches until its bottom is adjacent to the 20-cm mark on the meterstick. Based on this measurement, the value of the spring constant is
6.37 kg/s2.
637 kg/s2.
0.00637 kg/s2.
unknown.
0.650 kg/s2.
Where i thought it was 6.37; apparently it is unknown because you don't know that the spring's bottom was at 0cm when it started =/ Still not sure how it will help me with the first one though [the first question doesn't state that either]
For the first one:
Take the two points (use the weight) and plot them on a graph... your gradient is the spring constant.
Alternatively k = (m2 - m1)g / (x2 - x1)
Ugh, so it was the difference in the mass and distance; no idea why i took the sum. Thank you.
