What is the effect of arranging two springs in series?
In summary: You get an equivalent spring constant of K = 4.76. This is less than the stronger (K2=100) spring, because the stronger spring sees the weaker (K1=5) spring first.
chrom68
I have two springs arranged in series (remember circuit diagrams from physics class!).
One has a low stiffness constant (K1 = 5) and the other connected to it has a much higher contant (K2 = 100). According to the equation (as used in wikipedia):
[tex]
\frac{1}{k}=\frac{1}{k_1}+\frac{1}{k_2}
[/tex]
http://en.wikipedia.org/wiki/Hooke%27s_law"
Question 1)
Using this i get my equivalent spring constant to be K = 4.76, which is less than K1?
I don't understand why. I would expect the equivalent constant to be much higher (but less than K2=100).
Question2)
This formula doesn't consider the initial lengths of each spring. How could it do so?
[tex]
[/tex]
Question 1)
Question2)
Probably best to draw the springs in their initial state, and then compressed under some force. You should be able to derive the equation based on that.
The overall K will be lower than the weaker K, because your force "sees" the weaker K, plus some additional compression beyond what just the weaker K offers. Thus, the overall K appears a bit weaker than the weaker K. Make sense?
Imagine you have a very soft spring and a very hard spring in series.
You haven't done anything to make the soft spring any harder so the overall stiffness can't be any more than the soft spring (imagine attaching the soft spring to an infinite stiffness rod).
But you have added a strong spring which will give a little (however small) and so the overall system must have a little more give = overall stiffness must be less
I understand that the soft spring doesn't become any harder therefore shouldn't the overall stiffness still be greater than K1 (by just a small amount)? Surely adding a stiffer spring in series wouldn't make the stiffness weaker overall.
Draw the drawings I suggested in my post, and work through the numbers with some examples. What do you find?
Quiz Question -- what do you get for the composite K when you put two springs with identical K values in series? Why?
1. What is the formula for calculating the spring constant in series?
The formula for calculating the spring constant in series is k_total = k1 + k2 + ... + kn, where k1, k2, etc. are the individual spring constants.
2. How do you calculate the equivalent spring constant in series when the springs have different spring constants?
To calculate the equivalent spring constant in series when the springs have different spring constants, use the formula k_equiv = 1/(1/k1 + 1/k2 + ... + 1/kn).
3. Does the equivalent spring constant in series increase or decrease compared to the individual spring constants?
The equivalent spring constant in series always decreases compared to the individual spring constants. This is because the effective stiffness of the combined springs is lower due to the added flexibility.
4. Can the equivalent spring constant in series be negative?
No, the equivalent spring constant in series cannot be negative. This is because springs in series always add up to a positive value, and the formula for equivalent spring constant in series involves taking the reciprocal of the sum of the individual spring constants.
5. How can the equivalent spring constant in series be used in real-world applications?
The equivalent spring constant in series is a useful concept in physics and engineering for modeling and analyzing systems with multiple springs in series. It can be used to calculate the overall stiffness of a system and determine how much force is required to stretch or compress the springs. This can be applied in various fields such as in designing suspension systems for vehicles, analyzing the behavior of elastic materials, and understanding the mechanics of biological systems.
  • Mechanics
  • Mechanics
10K
