Spring oscillation kinematics question.
The discussion focuses on a physics problem involving a massless spring and a ball that falls onto it, leading to oscillation. Participants clarify that when the ball is at height y above the spring's original position, both gravitational force and spring force are acting on it, with the spring exerting a downward force. The net force on the ball is expressed as the sum of these forces, leading to the equation a = -ky/m - g for acceleration as a function of height y. There is confusion about the attachment of the ball to the spring and its implications for potential energy, but the final consensus is that the spring's force must be considered even after the ball passes the equilibrium point. Understanding these forces is crucial for solving the problem accurately.
Ishida52134
A massless spring with sprint constant k is vertically mounted so that bottom end is firmly attached to the ground, and the top end free. A ball with mass m falls vertically down on the top end of the spring, becoming attached, so that the ball oscillates vertically on the spring. What equation describes the acceleration a of the ball when it is at a height y above the original position of the top end of the spring? Let down be negative, and neglect air resistance; g is the magnitude of the acceleration of free fall.
F = -kx
vf^2 = vi^2 + 2ax
Ei = Ef
KE = 1/2 mv^2
PE of spring = 1/2 kx^2
For this problem, I tried to work backwards given the height y. And I used the kinematics formula and plugged in the intial speed at the point when the ball is oscillated back at the equilibrium of the spring and the final speed being at height y.
Then I worked with the F= -kx, letting the force equal to the weight mg, and used 1/2 kx^2 = 1/2 mv^2. then I solved for velocity and plugged that in the equation to find the final velocity at y.
I think I went somewhere wrong in here because none of the answers matched.
Btw, this a number 16, from the 2008 F = ma exam.
And if anyone has enough time, can someone please explain to me the best way of studying for this exam?
Would it be a good idea to read the entire mechanics part in the book Fundamentals of Physics? Because I feel I don't really grasp all the material and understand everything.
thanks.
Accelerations come from forces, what forces are acting on the ball?
gravity, forces from the spring?
When the ball is at a height y above the original position of the top end of the spring, is the spring in contact with the ball ?
no, it says y above the original position of the top end of the spring.
OK, then at that position, what force is acting on the ball ?
gravitational force?
The question does say "A ball with mass m falls vertically down on the top end of the spring, becoming attached" which makes me think that the mass is in some way "stuck" to the spring which would mean that the spring does exert a force on the ball once it has passed it's equilibrium point.
it does... it attaches to the spring and goes past the equilibrium point on the spring until the spring goes up again which launches the ball.
so does anyone have any idea about how to do this.
Good point! I missed that.
Well that makes sense, because then it says it oscillates. I must have missed that too.
@ Ishida52134,
This means that the ball is not launched.
So above the equilibrium point, the spring is being stretched by the ball.
okay so how do you do it...
When the ball is a height, y, above the original position of the top end of the spring, what is the force exerted on the ball by the spring? ... What is the force exerted on the ball by gravity?
What is the direction of each of these forces ?
spring: ky
gravity: -mg
following standard coordinate axes.
What is the net force (sum of the forces) on the ball? What does this net force equal to according to Newton's 2nd Law?
ky - mg = ma?
can u just tell me how to do it instead of asking me questions over a whole week. I honestly don't want to spend 1 week figuring out how to do one problem.
Ishida52134 said:
spring: ky
gravity: -mg
When y is positive, assuming that is above the spring's equilibrium position, then the spring exerts a downward force on the ball. That force should be negative.
so how do you do the problem...
Force exerted by spring: -ky
Force exerted by gravity: -mg
Call Mr. Newton to find the acceleration.
-ky - mg = ma? ...
Just divide both sides to solve for a
a = -ky/m - g
The original question asked "what equation describes the acceleration when the ball is y is above the original position of the top end of the spring?" which is almost like asking find a(y), acceleration as a function of y.
a = -ky/m - g
thanks. I thought it'd be affected by the potential energy of the spring and I was confused whether the ball becomes attached even after it passes the equilibrium point when it goes back up.
