Spring problem on work and force
To determine the speed of a 0.4 kg mass after it is released from a compressed spring with a spring constant of 400 N/m, energy conservation principles apply, where the potential energy stored in the spring converts to kinetic energy. The initial potential energy of the spring can be calculated using the formula PE = 0.5kx^2, where x is the compression distance. After the spring decompresses, the mass's speed can be found using the kinetic energy formula KE = 0.5mv^2. For the second part of the problem, clarification is needed regarding whether the hill is 0.5 m high and if the speed is being asked for at the top of the hill. The discussion emphasizes the importance of understanding energy conservation in solving the problem.
brnnpink4
a .4 kg mass compresses a spring of .2m. The spring constant is 400n/m How fast is the mass moving after the mass is released and the spring uncompresses? If the mass is going up a .5m hill, how fast is it going?
PE+KE=w
PE=mgh
KE=.5mv^2
PE=.5(9.8)(x)
To find how fast its moving right after the spring decompresses, use energy conservation. Elastic potential energy is lost, and kinetic energy is gained.
You'll have to clarify the second part -- is the hill 0.5m high? Do you mean how fast is it going at the top?
The hill is .5m high
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
