SR830 Lockin Amplifier
The discussion centers on using the SR830 Lock-In Amplifier (LIA) to measure the current of a Hall bar device. The user seeks to apply a sine wave voltage at one terminal while measuring current at the gating electrode, treating the setup as a capacitor. Concerns arise regarding potential overload in the X and Y outputs due to high resistance values. The conversation also touches on the distinction between measuring DC and AC magnetic fields and the importance of understanding the experimental setup. Clarification through a diagram is requested to better visualize the proposed method.
K_c_1
TL;DR Summary
How can i use sr830 amplifier to measure current(I) of a hall device?
I want to measure the current of hall bar device using sr830 LIA. it is possible with sr830 to measure current but how ?
Welcome to PF.
What have you found in your research on this so far? How much have you used Lock-In amplifiers in the past, and for what tasks? What does your experiment look like so far for measuring the current of your Hall sensor (versus magnetic field?)?
The SR 830 has a current measurement mode shown in the user manual. However, most Hall devices provide an output voltage.
Do you want to measure a DC or AC magnetic field?
Likes K_c_1 and berkeman
Thankyou all for the reply
actually what i want to do was put sin out at one voltage terminal and A at the gating electrode, From there measure the current. basically it will be acting as a capacitor. the resistance between the voltage terminal and gate electrode is in Mohm. So by using A(Current input 10^6 or 10^8) i think it is possible but it might show overload in X and Y
I'm sorry but I don't understand what you want to do. Could you post a diagram?
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
