Starship + 2 different planets?
  • Thread starter Thread starter good.you?
    Planets Starship
The discussion revolves around a physics problem involving projectile motion on Earth and an unexplored Planet X. A ball rolls off a table in a starship, landing at a distance D on Earth, and at 2.76D on Planet X. To determine the acceleration due to gravity on Planet X, one must analyze the projectile motion equations, focusing on the horizontal and vertical components of the ball's trajectory. The initial velocity remains constant, so the challenge lies in deriving the range expression based on the height and initial speed. Understanding how to eliminate time from the equations is crucial for finding the relationship between the distances and gravitational acceleration.
good.you?
The problem from my textbook is:
Inside a starship at rest on earth, a ball rolls off the top of a horizontal table and lands a distance D from the foot of the table. This starship now lands on the unexplored Planet X. The commander, Captain Curious, rolls the same ball off the same table with the same initial speed as on Earth and finds that it lands a distance 2.76D from the foot of the table. What is the acceleration due to gravity on Planet X?
The 4 basic equations of motion:
V=Vi + a x delta t
S=Si + Vi x delta t + 1/2at^s
S=Si + 1/2(V+Vi)delta t
V^2= Vi^2 + 2a(S-Si)
I know the initial velocity is the same in both cases, I figure you have to substitute the initial velocity in one with an equation with the acceleration on earth. I'm kind of lost from this point.
What I really need is some one to explain how to solve it.
This is a projectile motion problem. You need to find an expression for the range of the projectile given that it has initial velocity v0 only in the horizontal direction and starts at height h above ground. Can you find such an expression?
I'd have to rearrange equations and substitute them into one another and I wouldn't know where to start.
Start by writing expressions for the horizontal position of the ball at any time t and for the position of the ball above ground at any time t. Eliminate the time and find an expression giving the dependence of the range on the vertical height and the initial speed.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
