akhand121
- 1
certain vehicles can be started by keeping the gears engaged while certain others cannot...how ?
akhand121 said:certain vehicles can be started by keeping the gears engaged while certain others cannot...how ?
Engaging gears when starting a vehicle allows the engine to transfer power to the wheels, which allows the vehicle to move forward or backward. It also helps control the speed and direction of the vehicle.
No, it is not recommended to start a vehicle with the gears engaged. This can put unnecessary strain on the engine and transmission, potentially causing damage.
It is generally recommended to shift the vehicle into neutral when parked. This reduces strain on the transmission and makes it easier to start the vehicle. However, some vehicles have a safety feature that requires the vehicle to be in gear in order to start.
If the vehicle stalls while in gear, you should first try to restart the engine while in neutral. If that does not work, you may need to push the vehicle to a safe location and check for any issues with the transmission or engine.
Yes, you can switch gears while the vehicle is in motion. However, it is important to do so smoothly and at an appropriate speed. Abrupt gear changes can cause damage to the transmission and affect the vehicle's performance.
