Stat-Mech problem: pressure from a partition function
The discussion revolves around a statistical mechanics problem involving the pressure of a helium gas in a vessel after some atoms adhere to the walls, affecting the partition function and final pressure calculation.
  • Participants explore the relationship between the initial and final pressures, questioning how to express the final pressure in terms of the partition function. There are attempts to relate the number of adsorbed atoms to the partition function and the overall system behavior.
Some participants suggest summing the partition function over all allowable values of adsorbed atoms to derive the final pressure expression. There is acknowledgment of the dynamic nature of the adsorption process and its impact on the system's micro-states.
Participants note the complexity of the problem and the potential need for additional information or clarification regarding the partition function and its derivation.
TroyElliott
A vessel having a volume ##V## initially contains ##N## atoms of dilute (ideal) helium gas in thermal equilibrium with the surroundings at a temperature ##T##, with initial pressure ##P_{i} (T ,V ) = \frac{NRT}{V}## . After some time, a number of helium atoms adhere to the walls of the vessel, each occupying one of ##N_{0}## available surface states having binding energy ##\Delta##, where ##N_{0}>>N.## When ##M## atoms are adsorbed on the surface, the partition function for the system is given by
$$Z = \frac{q^{N-M}(N_{0}e^{\beta \Delta})^{M}}{M!(N-M)!}$$
where ##q = V\sqrt{\frac{mkT}{2\pi\hbar^{2}}}.##
Show that the final pressure is ##P_{f} = P_{i}(1+\frac{N_{0}}{q}e^{\beta \Delta})^{-1},##
after equilibrium is reached between the gas and the surface.
##P_{final} = \frac{1}{\beta}\frac{\partial \ln{Z}}{\partial V}##
After using ##P = \frac{1}{\beta}\frac{\partial \ln{Z}}{\partial V},## I get ##P = \frac{(N-M)}{\beta V}.## I am not seeing how I can write this such that the answer appears like ##P_{f} = P_{i}(1+\frac{N_{0}}{q}e^{\beta \Delta})^{-1}.## Any ideas on where to go from here?
Edit: From here I thought that I could relate ##N-M## to the following $$<M> = \frac{Ne^{\beta \Delta}}{Z},$$
or
$$<N-M> = \frac{N}{Z}$$
I hope I'm not leading you astray. But, I believe the actual partition function for the system would be obtained by summing the above expression for ##Z## over all allowable values of M. The sum can be carried out without much difficulty and the resultant ##Z## appears to lead to the given expression for the final pressure.
The reason for summing over M is that M will vary in time as molecules in the gas phase randomly attach to the wall and then get kicked off the wall by collisions from other molecules in the gas phase. So, the possible micro-states of the system will include states with various values of M.
Thank you for the suggestion. I think it would be strange for the writer of the problem to purposely call ##Z## the partition function, but then not include a summation over the states. I will take a look at your suggestion and see if it leads to the correct answer. Thanks!
