State Space Analyis - the 'B' matrix
The discussion focuses on the transition from equations 3-17 and 3-18 to 3-20 in state space analysis, emphasizing that 3-20 is simply a matrix representation of the same simultaneous equations. The user questions the representation of the 'u' part of the matrix, wondering why it can be expressed differently. It is clarified that both representations are valid, but the choice depends on the context of the analysis. The orderly nature of matrix multiplication is highlighted as crucial for understanding the transformation between these equations. Ultimately, the user acknowledges their initial question as unnecessary after the explanation.
phiby
Below is a screen shot from state space analysis in "Control Engineering" by Ogata.
http://www.flickr.com/photos/66943862@N06/6230432028/"
I am trying to get at 3-20 from 3-18.
Can't the u part of the matrix also be written as
[1/m 0]T instead of [0 1/m]T?
What's the rationale in choosing one over the other?
Astronomy news on Phys.org
There is nothing to do to get to 3-20...if you got to 3-18, you are already at 3-20...well, if you got to 3-17 AND 3-18, you are already at 3-20.
3-20 is exactly the same as 3-17 and 3-18 together, it is simply the expresion of the same set of simultaneous equations, but in matrix form:
Code:
x1dot = (  0 )x1 + (  1 )x2 + ( 0 )u
x2dot = (-k/m)x1 + (-b/m)x2 + (1/m)u
When 3-17 and 3-18 are written as above, it should be clear to you why 3-20 looks the way it does, right?
Keep in mind the orderly manner in which matrix multiplication works, too, in order to answer your question.
Code:
Yes, I got that. My original question was silly!
Publication: Redox-driven mineral and organic associations in Jezero Crater, Mars Article: NASA Says Mars Rover Discovered Potential Biosignature Last Year Press conference The ~100 authors don't find a good way this could have formed without life, but also can't rule it out. Now that they have shared their findings with the larger community someone else might find an explanation - or maybe it was actually made by life.
TL;DR Summary: In 3 years, the Square Kilometre Array (SKA) telescope (or rather, a system of telescopes) should be put into operation. In case of failure to detect alien signals, it will further expand the radius of the so-called silence (or rather, radio silence) of the Universe. Is there any sense in this or is blissful ignorance better? In 3 years, the Square Kilometre Array (SKA) telescope (or rather, a system of telescopes) should be put into operation. In case of failure to detect...
Thread 'Could gamma-ray bursts have an intragalactic origin?'
This is indirectly evidenced by a map of the distribution of gamma-ray bursts in the night sky, made in the form of an elongated globe. And also the weakening of gamma radiation by the disk and the center of the Milky Way, which leads to anisotropy in the possibilities of observing gamma-ray bursts. My line of reasoning is as follows: 1. Gamma radiation should be absorbed to some extent by dust and other components of the interstellar medium. As a result, with an extragalactic origin, fewer...
