States of a spin 1/2 particle in a magnetic field
The discussion revolves around the quantum mechanics of a spin 1/2 particle in a magnetic field, specifically focusing on the Hamiltonian and the eigenstates of the spin operators Sz and Sx. The original poster presents a problem involving the calculation of normalized energy eigenstates and eigenvalues, as well as the eigenstates of Sx in relation to Sz eigenstates.
  • Participants discuss the calculation of the Hamiltonian and its eigenvalues, questioning the normalization of the resulting eigenstates. There is an exploration of the eigenstates of Sx and the relationship to Sz eigenstates, with some participants expressing confusion over the equations derived and the normalization process.
Some participants have provided insights into the calculations and the nature of the eigenstates, while others have raised questions about normalization and the correctness of the derived values. There is an ongoing examination of the eigenvalue equations and the implications of using the Pauli spin matrices.
Participants note the importance of ensuring that the eigenstates are normalized and question the assumptions made in the calculations. There is also mention of the representation of the matrices in relation to the Sz eigenstates, which may affect the interpretation of the results.
ulcrid
Hi, for my quantum mechanics course I'm confronted with the following question:
A spin 1/2 particle has the following eigenstates of Sz: |+> = (1 0) and |-> = (0 1). A magnetic field is pointing in the z direction, B = (0,0,B). The Hamiltonian is H = -B * n, with n = -(e/mc)S and S = h/4pi * s (with B, n, S, and s vectors and H of course an operator).
The questions are a) to find the normalized energy eigenstates and eigenvalues and b) to find the normalized eigenstates and eigenvalues of Sx in terms of the eigenstates of Sz.
The Pauli spin matrices are most important here, for a) only the z component is relevant as the magnetic field only has a z component and the Hamiltonian is defined as -B * n. For b) I think the x component is also relevant.
sz=
(1 0)
(0 -1)
sx=
(1 0)
(0 1)
I think I got the most far on question a). I calculated H and found it to be H = (ehB/4pi*mc)*
(1 0)
(0 -1)
Then, using the determinant of (H - lambda * I) I calculated the eigenvalues of H: lambda = +/- (ehB/4pi*mc). After that, I used the eigenvalue equation Av = lambda*v to find the eigenvectors (1 0) and (0 1). I don't think that should be surprising though because somewhere in the book (Introductory Quantum Mechanics by Liboff) it says that Sz and H have the same eigenfunctions.
But are these normalized? And are these values/vectors correct?
On question b) I don't really know what to do - if I try finding out the eigenstates of Sx I get stuck on the vectors. I get equations like h/4pi (b a) = (a b) which doesn't have a solution except for a = b = 0 which obviously is incorrect. How do I find the correct eigenstates? And how do I then find out how to write them as combinations of eigenstates of Sz? Hope someone can help!
(1 0)
(0 -1)
If the vectors are normalized, they'd have a magnitude of 1. What are the magnitude of your vectors?
You need to show more details of your work. You might just be dropping a constant somewhere.
The matrix representation of Sx you're using is with respect to basis of the Sz eigenstates, so the eigenvectors you find will already be representations in terms of the eigenstates of Sz.
Well, the magnitude of the vectors seems to be 1. After all, |(1 0)|2 is 1. So that would be okay?
For the second question I used the Pauli-spinmatrix of Sx:
Code:
[U]h[/U]   (0 1)
4pi (1 0)
Then, I can use det(Sx-lambda*I) = 0 to get lambda2-1 = 0 so lambda is either 1 or -1.
Using that in the eigenvalue equation I get Sx*v = +/- v
Which gets me to
Code:
[U]h[/U]   (0 1)(a) = +/- (a)
4pi (1 0)(b)       (b)
Which is equal to
Code:
[U]h[/U]   (b) = +/- (a)
4pi (a)       (b)
Which in my view is only solvable for a = b = 0. ?
Your eigenvalues should be [itex]\pm\hbar/2[/itex]. Can you see the mistake you made in calculating them? If you fix those, the eigenvectors should work out for you.
Ah, yes, I see where I went wrong. And because I used the Pauli-spinmatrix for Sx, which apparently already is in the Sz/S2 representation, these vectors and eigenvectors are already in terms of the eigenstates of Sz?
