louza8 said:
Edit:
Still having some trouble with the direction of By and Dy :(
I have it in my head that the forces must be compressive or tensile, but they don't have to be do they? Could you explain this point a little more or check the following to see if I've got it right?
∑Fx=0; Dx+Bx+981
Bx=-3335.4 - 981N
Bx= -4316.4N
Bx=B*cos(32deg)
B=Bx/cos(32deg)
B=-5089.81/cos(32deg)
By=sin(32deg)*B
By=-26997.18N ------------------> is this the right direction? like from top to bottom
Therefore
∑Fy = 0; By+Dy
Dy=2697.18N ----------->is this the right direction? like from bottom to top?
Or have I muddled up my directions here?
Hopefully these will be my last questions ;)
You seem to be a bit uncareful with your signs, but it's hard to tell without a picture.
I think your first equation should be:
∑Fx=0; -Dx+Bx+981=0
based on how you chose Dx earlier.
Furthermore, you seem to assume that the force at B is aligned with the section, which in this case isn't. The moment sum will show that.
And take care that the force at B is actually 2 forces, which are equal and opposite.
BD pulls AC up, and simultaneously AC pulls BD down, in such a way the the joint remains in the same place.
It should work out that the By on section BD is pointed down.
And Bx on section BD is pointed left.
Dy (on section BD as well as on the entire system) would indeed be pointing up.
I'd suggest you draw a diagram of the entire structure with the external forces, showing explicitly what directions you have chosen for those forces.
And I'd suggest you draw a diagram of BD with the forces acting on it.
And finally a diagram of AC.
Note that in the diagram of AC the (chosen) forces at B are the same as in the diagram of BD but exactly opposite.
If you have calculated everything correctly, you'll see that when you work out section AC works, that all forces are already known, making it possible to verify that you made no mistakes.
If section AC turns out not to be in equilibrium, it's very likely you made a mistake with a minus-sign.
Cheers! :)
