Static electricity and circuit breakers
Electric technicians often ground a wire before touching bus bars on high tension circuit breakers to prevent shocks from static or residual charges, even when the breaker is isolated. Static charge can accumulate due to induced charges from nearby components, especially in large power transformers with significant capacitance. This residual charge can be dangerous, persisting long after testing, as evidenced by past incidents of fatalities. Safety protocols dictate that all conductors must be grounded or discharged before handling to ensure worker safety. Overall, it is critical to maintain strict safety practices when working with high voltage systems to mitigate risks associated with residual and induced charges.
magmash
Hi
I have seen electric technicians while racking out high tension circuit breakers, use a wire that has one end grounded and they use the other end to touch the bus bars on the breaker in case of a static charger, they carry out this procedure before they do any work on the CB in case they get shocked by a static charge, is it necessary to carry out such a procedure even tho the breaker is completely isolated ?
How can static charge be built in a case like that, where there is no friction ?
...is it necessary to carry out such a procedure even tho the breaker is completely isolated ?
That's like asking if it is necessary to always assume that a gun is loaded.
Charge can also be induced.
The main point is that the workers have no idea what has been happening to the component.
Large power transformers can have a lot of capacitance between the windings and the core and the metal case.
This capacitance gets charged and discharged from the voltages on the windings in normal operation.
If the supply is removed rapidly some residual charge could be left on the capacitance from the winding to its metal surroundings.
This capacitance can be deadly when transformers are being tested. Large DC voltages are used to test transformer breakdown capability and if this is not carefully discharged, it can persist for days.
Someone was killed about 20 years ago by a transformer which was still holding a charge two days after high voltage testing.
A few points : In general I would not refer to this as static, but residual charge - because the insulation on Medium (600-72KV) and High Voltage ( >72KV) - although I do not know of any rack out HV breakers... ok back on track, because of the very high insulation, it is typical / common to have a residual charge left on the breakers conductors.
As a matter of practice - safety policy etc... EVERY conductor you touch MUST be grounded..discharged first. You do not touch ANYTHING unless you KNOW ( not just think) it is safe.
-- A note back on the HV systems, it is also common for just the wind to leave a static charge on UNGROUNDED conductors - large transformers have pumped oil cooling systems, also a problem.
I think I would add "don't touch it anyway".
I have seen these charges build up again even after being discharged.
You can always use insulated pliers etc to keep your fingers away from potential danger.
"Do not touch" does not really work if you have to work ON the breaker - the disconnect points (stabs/receivers) are cleaned and this is where many of the test connections are made. Once dawn out of the cubicle, and discharged - there is little risk, make on these is 36KV Class, up to about 3000A - I have not seen draw out breakers higher voltage than that. - Although we used to wrap a wire or have light alligator jumpers on all points not under test - these can get induced V from hi-pot testing.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
