Static Equilibrium and tension of cables
The problem involves a static equilibrium scenario where a neon sign, along with three cats, is suspended by two cables. The participants are tasked with calculating the tension in each cable while considering the forces and torques acting on the system.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster attempts to find the center of mass of the system and set up equations based on the forces acting in the y-axis. Some participants question the assumption that the tension in both cables is equal and suggest considering torques about different points to simplify calculations.
Participants are exploring various methods to calculate the tensions in the cables. Some guidance has been offered regarding the use of torque and the choice of pivot points for calculations, leading to different expressions for the tensions. There is no explicit consensus on the final values, but some participants express confidence in the results derived from the suggested methods.
Participants are working under the constraints of a homework assignment, which may limit the information available and the methods they can employ. The discussion reflects a mix of interpretations regarding the setup and calculations involved in the problem.
Juniper7
A 30Kg neon sign is suspended by two cables, as shown. Three neighbourhood cats (5.0 Kg each) find the sign a comfortable place. Calculate the tension in each cable with the cats are in the positions shown.
xCM = m1x1 + m2x2 ...
mtotal
yCM = m1y1 + m2y2 ...
mtotal
F = mg
I found the centre of mass (CM) by assigning each cat a coordinate using the bottom left corner of the sign as the origin with (x,y). So:
Cat1 = (0.2,0.5)
Cat2 = (1.8,0.5)
Cat3 = (2,0)
Sign = (1,0.25) --> the centre of the sign
Using the above two equations I found the centre of mass of the cats and sign to be (1.11m,0.278m)
There should be no forces in the x-axis and the forces in the y-axis should all cancel out so:
T1cable + T2cable = mg
I know the position of each cable from the picture so: (using only y-axis position)
T1(0.5m) + T2(0.5m) = (45kg)(9.81)(0.278m)
The tension in each cable should be equal? Or, because one cable is farther from the CM it should have less tension? Does this mean I should be taking into account the x axis? Please help!
Looks like you y'd when you should have x'd. Torque is force times perpendicular distance from line of action of force to any point chosen wisely.
Hm ok. So:
T1(0.2m) + T2(1.8m) = (45kg)(9.81m/s2)(1.11m)
T = 245N
So that means each cord has a tension of 245N?
Juniper7 said:
Hm ok. So:
T = 245N
No, your equation was ok but then you assumed that T1 and T2 were equal and got an erroneous result. To simplify matters, try summing torques not about your assumed origin at (0,0), but rather, about the point at the base of the sign at coordinate (0.2,0). You can choose any point, but keep it simple. In this manner, you can solve for T2 directly, because there will be no torque from T1, then continue...
Ok. So coordinates for each point would be in relation to (0.2,0) If I do it how you suggest:
T1(0m) + T2(1.6m) = (45kg)(9.81m/s2)(0.91m)
T2 = 250.8N
Then can I use my earlier equation to solve for T1?
0.2T1 + (250.8N)(1.8m) = (45kg)(9.81m/s2)(1.11m)
T1 = 190.4N
You look to be correct. I worked it out separately and got this result, so I hope you're right :p.
yes, looks good!
Thanks!
14K
