Static friction between two stacked blocks a 3rd law pair?
The discussion revolves around the concept of static friction between two stacked blocks and whether the forces involved constitute a third law pair. Participants explore the implications of static friction in a scenario where the blocks are at rest and the forces acting on them.
  • One participant notes that static friction acting on block A from block B is necessary for A to remain at rest, suggesting a force of 20N to the right.
  • Another participant questions the notion that A could exert a leftward force on B while remaining stationary, prompting a discussion about the nature of forces in this context.
  • It is proposed that the static force from B to A applies an opposite force on B, leading to a consideration of the forces acting on both blocks.
  • Participants discuss whether the reaction force from the static friction acting on A is still considered static friction for B, with some suggesting that B can experience static friction acting in both directions.
  • Additional notes clarify that the friction forces between A and B are not action/reaction pairs, leading to further inquiry about the implications of this statement.
  • There is a suggestion to consider how the situation would change if the blocks were nailed together or if they were moving with constant velocity.
Participants express differing views on the nature of static friction and its implications for the forces acting on the blocks. There is no consensus on whether the friction forces constitute action/reaction pairs, and the discussion remains unresolved regarding the interpretation of these forces.
Participants highlight the complexity of the forces involved, noting that static friction does not necessarily imply a straightforward action/reaction relationship. The discussion also touches on the conditions under which the blocks are stationary and the potential effects of different scenarios.
jmoney
I'm trying to get my head around this scenario:
The blocks are at rest, despite the tension forces acting on them.
It is obvious that the static friction acting on A from B is 20N to the right for A to remain at rest (the max might be a lot higher).
But does this produce an equal and opposite reaction on B? It seems to me that the static friction should have some reaction... but it also seems silly to think that A could exert a leftward force on B when A isn't even moving.
Are the forces acting on B (before possible floor friction)
20N <--- B --> 5N or just B--->5N
Thank you, and I hope I have been clear enough! This is my first post on this forum.
Why "silly"?
You are told that the blocks are stationary?
Than means the net force on A is zero ... so what are the forces on A?
Note: if the forces are not strong enough to overcome static friction - doesn't that mean the two blocks are stuck together?
Okay, "silly" was a poor choice. I think that the static force from B to A that holds A in place applies an opposite force on B.
Assuming that is the case, and they're stationary:
A is stationary because the vertical net force is Fn-Fg=0, and horizontally because of Fsf-Ft=0.
B is also stationary, the vertical forces are Fn(floor)-Fn(A)-Fg=0,
horizontally: Ft-Fsf(reaction from A)=-15, but it must be 0.
So there is either 15N of static friction from the floor, or, there could be another static force that is keeping B from moving left; and the floor could be frictionless in that case.
Would the reaction force from the static friction acting on A still be considered static friction for B? Can B have static friction acting in both directions?
Sure. Think of the friction force as an interaction between two objects: A and B exert a static friction force on each other.
Why not? The two friction forces acting on B would act on different surfaces.
Additional notes:
1. friction of A on B and friction of B on A are not action/reaction pairs.
2. how does the situation change if the blocks were nailed together?
3. if the blocks were not stationary - but both moving with the same constant velocity wrt the floor - how would that change your analysis?
Simon Bridge said:
Additional notes:
Why do you say that?
Could be a source of the puzzlement ... 3rd-law pairs don't cancel out.
True. But why did you say:
Simon Bridge said:
Additional notes:
I was hoping to get something like your response - with details, from OP.
On reflection... it may have been more effective to direct that the AB force does not cancel the BA force.
  • · Replies 20 ·
  • · Replies 37 ·
