The discussion revolves around the procedure for static mass balancing of assemblies with a total mass of 100 kg, focusing on methods to determine the center of gravity (CG) for subsystems weighing between 2.5 to 10 kg. Participants explore various techniques and standards related to this process.
- Technical explanation
- Exploratory
- Debate/contested
- One participant suggests hanging the complete system freely in air to check the placement of the exact center as an appropriate method for static mass balancing.
- Another participant mentions using three different hanging points to determine the center of gravity but is unsure of any ASTM specifications for this method.
- A question is raised about the specific points from which to hang the assembly, particularly for a cubical box shape.
- One participant recalls using random points spread over the body for determining CG, particularly for irregular shapes like automotive seat assemblies.
- Another participant confirms the method of hanging the object from three points and drawing vertical lines down to find the intersection point as the center of gravity, noting that if the lines form a triangle, the center of the triangle can be used instead.
- A later reply discusses a pendulum test used for determining the mass moment of inertia of rotor disk assemblies, mentioning its relevance despite advancements in modeling software.
Participants generally agree on the method of hanging the assembly from three points to determine the center of gravity, but there is no consensus on specific standards or the exact points for hanging, leading to multiple competing views on the best approach.
Some limitations include the lack of specific ASTM standards mentioned, uncertainty regarding the optimal hanging points for different shapes, and the dependence on the assembly's geometry for the proposed methods.
