Statistical Mechanics question: calculate energy difference
trelek2
In a system of N weakly interacting particles each particle can be in one of M energy states:
E_1 < E_2 < ... < E_M
At T=300K there are 3 times as many particles in E_2 as in E_1.
Calculate E_2 - E_1
This is not my homework, just a tutorial question, I'm revising and I'm not sure if I'm understanding this stuff. Let me know if this is correct and if not please tell me how it should be done.
I consider only particles of Energies E_1 and E_2.
Probability of particle in state E_1=
P(E_{1})=Z^{-1}exp(- \frac{E_{1}}{kT})=0.25
Probability of particle in state E_2=
P(E_{2})=Z^{-1}exp(- \frac{E_{2}}{kT})=0.75
Z=exp(- \frac{E_{1}+E_{2}}{kT})
Hence:
E_{1}-E_{2}=kT(ln(1/3))
How do you know the true probabilities are 0.25 and 0.75 without knowing the partition function. The particle also has a probability of being in a higher state.
The only thing you know is the ratio of the probabilities:
\frac{P(E_2)}{P(E_1)} = exp(-\frac{E_2-E_1}{kT}) = 3
Which would make E_2 < E_1 for the single particle (opposite of what you said initially).
Edit: Dealing with N particles can be tricky since you have a lot of combinations. You can have 1 particle in E_1, 3 particles in E_2, and the N-4 particles can occupy any of the higher states. So you might want to limit yourself to a single particle, or a set number of particles.
To solve this, I first used the units to work out that a= m* a/m, i.e. t=z/λ. This would allow you to determine the time duration within an interval section by section and then add this to the previous ones to obtain the age of the respective layer. However, this would require a constant thickness per year for each interval. However, since this is most likely not the case, my next consideration was that the age must be the integral of a 1/λ(z) function, which I cannot model.
